You're a Bryston Fanboy/Fangirl if...
0 Members and 1 Guest are viewing this topic. Read 3342 times.
Mag
« on: 13 May 2014, 04:51 am »
When you die you want to be wrapped in the Bryston speaker sack.:lol:
spinner
Re: You're a Bryston Fanboy/Fangirl if...
« Reply #1 on: 13 May 2014, 05:06 am »
.............you have a likeness of  James  Tanner tatuded  on your................... :oops:
Elizabeth
« Reply #2 on: 13 May 2014, 05:34 pm »
Defend Bryston amps against 30 year old comments that Bryston amps are 'dry' sounding. Or 'not very good'.
Typical guy writing about how bad Bryston amps are: "Yes I am an expert on Bryston Amps as i heard one back in 1984 while drunk, but I remember it well as i stood in the same room with it for at least two minutes.. Terrible amp, wasn't even turned on, damn junk."
Dealing with that...
RDavidson
« Reply #3 on: 13 May 2014, 07:18 pm »
......you're not sure your 28BSST 2's have enough power and are contemplating buying a second pair.
turnovertherecord
  • rain,fog,snow,sun,known to happen on the same day
« Reply #4 on: 13 May 2014, 07:51 pm »
If your Avatar is ?
Also if you sold your bryston to get a pass lab,krell and mcIntosh
Than sold all of that to return to Bryston :thumb:
vegasdave
« Reply #5 on: 25 Jun 2014, 07:43 pm »
 :lol: Exactly.
Mr. Don
« Reply #6 on: 26 Jun 2014, 02:22 am »
 ... you know how to properly pronounce Bryston.
grsimmon
  • Omni - the best way forward
« Reply #7 on: 26 Jun 2014, 05:41 am »
 - you are thoroughly familiar with the differences between SST and SST2
-  you are equally familiar with the (relatively) small change to the 20 year warranty that occurred x amount of years ago
-  you named one of your children Bryston
-  you continue to ponder,  sometimes out loud,  if/when Bryston will implement tone controls to their integrated amps
95Dyna
« Reply #8 on: 26 Jun 2014, 08:41 pm »
If you've told James you think Bryston Should come out with a turntable.
Your laptop background is a streetview of 677 Neal Dr. Peterborough, ON
JfTM
« Reply #9 on: 26 Jun 2014, 08:57 pm »
When you listen to the music, not the gear.
lowtech
« Reply #10 on: 26 Jun 2014, 09:59 pm »
You find this thread even mildly entertaining.   :lol:
john1970
« Reply #11 on: 27 Jun 2014, 12:24 am »
If the only non-Bryston equipment on your equipment rack is your Blu-Ray player and the other eight pieces of equipment are all Bryston.   8)
skunark
« Reply #12 on: 27 Jun 2014, 04:22 am »
You are a fanboy/girl if you are annoyed if the 12-volt trigger is a mini jack.
You are a fangirl/boy if you purchased an aluminum block to align the faceplates.
You are a fanboy/girl if you don't like the feel of plastic remotes.
You are a fangirl/boy if you keep asking about 19" faceplates for the BIT.... (hint..)
« Last Edit: 27 Jun 2014, 05:50 am by skunark »
ricko01
« Reply #13 on: 27 Jun 2014, 10:10 am »
(1) I you have a poster of James Tanner hanging in your bed room
(2) I you buy a non-Bryston integrated to replace your BP-26, but end up using the integrated as a power amp and the BP-26 still as your pre
Only (2) is true in my case.
Peter
alexone
« Reply #14 on: 28 Jun 2014, 07:34 pm »
...you are an AC member and frequently checking out the Bryston circle :wink:
al.
lossless
« Reply #15 on: 29 Jun 2014, 07:04 pm »
This is me through and through, just check out my avatar!   :thumb:
Mag
« Reply #16 on: 29 Jun 2014, 08:06 pm »
You have your local Bryston dealer on Speed Dial.
Mag
« Reply #17 on: 28 Sep 2020, 04:19 pm »
You have reached the pinnacle of Hi-Fi audio with Bryston gear. :thumb:
System: Bryston BCD-3, SP2, BDP-1, BDA-1, 2- 3B SST/2, Model T passives, Paradigm Studio 100 v2, Monster Power Conditioner AVS 2000, Yamaha MG-10 mixer, Tascam CD-RW901SL Pro-CD Recorder, Leawo Blu ray Player with i7 computer.
zoom25
« Reply #18 on: 28 Sep 2020, 04:29 pm »
...you come across someone name Bryson, and your first thought is "there should be a T in there!"
GSDaudio
« Reply #19 on: 28 Sep 2020, 05:05 pm »
Your eyes don't wander and you are completely satisfied for 20 years.
In 20 years you can upgrade and the improvement will be on the order of some exponential figure!
