anybody use Ortofon or Audio Technica
0 Members and 1 Guest are viewing this topic. Read 2688 times.
gagamut
« on: 9 May 2014, 01:35 am »
recently my LYRA Skala need to retip,so consider Ortofon Cadenza or Audio Technica AT ART7 cartridge,any comment?IS it match?thanks :D
rob400
  • Versalex and Audio Note for the rest
Re: anybody use Ortofon or Audio Technica
« Reply #1 on: 9 May 2014, 06:12 am »
What abut Dynavector? A superb match with WTL.
SteveFord
« Reply #2 on: 9 May 2014, 09:30 am »
Ortofon 2M Black for me and it sounds really good on both tables.
gagamut
« Reply #3 on: 10 May 2014, 03:13 am »
thanks for reply :D,
i also want to try Dynavector too,but recently don't want spend too much on Cartridge,may be later  :D
Erocka2000
« Reply #4 on: 10 May 2014, 01:16 pm »
The cheapest Cadenza is $1,200. You can get either the Dynavector 10x5, 20x2L or 17D3 for less than that. Don't quite understand your budget.
gagamut
« Reply #5 on: 10 May 2014, 01:22 pm »
Sorry for confusion,my budget should be under $800,
Erocka2000
« Reply #6 on: 10 May 2014, 01:57 pm »
Well, the 10x5 is $450 and the 20x2L is $850.
rob400
« Reply #7 on: 10 May 2014, 06:49 pm »
Well said Erocka. The 20xl2 is a fine cartridge.
threadkiller
« Reply #8 on: 12 May 2014, 03:33 pm »
The Ortofons are just plain ol bleh. They're there, not much more can be said about them- other than good marketing.  What's sad is that one gets whipped up over their great new table, yet then puts that on it. How does one know they've compromised their table? Their music? It's hard out there in hifi land.
