FS: ClassD Audio SDS254 Amplifier Upgrades **SOLD**
0 Members and 1 Guest are viewing this topic. Read 2054 times.
Nick77
For Sale ClassD Audio SDS254 Amplifier With $200+ Upgrades
125 watts @ 8ohm or 250 watts @4 ohm.  Adjustable Gain has proved very useful.
http://classdaudio.com/amplifier-kits/sds-254-kit.html
I cant believe I am selling this cause it sounds fantastic, I am one of the biggest fan boys of this amp around. But the DIY bug strikes again, building a more expensive DIY amp.
I built this DIY kit several years ago using premium parts and then upgraded the power supply to 60k capacitance with Panasonic TSHA caps, these caps are really hard to find. The cap upgrade took the unit to a whole another level in dynamics and micro resolution. The dymanics were increased across the spectrum but bass impact and articulation was the greatest improvement. Im almost certain you could never achieve this level of sonics for so little money. There is a very long list of happy campers in this 100+ page thread. Wired for single ended RCA’s, but can switched to balanced with jumper setting.
http://www.audiocircle.com/index.php?topic=76400.0
Many extras……..  $200+ Upgraded parts
Power Supply Upgraded to Panasonic TSHA 10k uF Capacitors Total 60k uF Capacitance $70
CMC- Red Copper Binding Posts  $35
CMC- Nickel free gold RCA $15
Furutech- Gold IEC W/Fuse Holder $25
Create Audio Nano Fuse  $15
Wiring- High Purity Solid Core Copper $15
On Off Rocker Switch $5
Custom Wood Case   $35
Labor   $$
Asking $350 + shipping        ********** SOLD ***********
SDS-254 Class D Audio Kit with Large Power Supply, AnTek 400VA Transformer, Molex Connectors for external LED's, power switch, and gain controls. High Quality Conductive Plastic Element External Gain Controls also included. Our new Super D Series audio power amplifiers are built on the highly acclaimed reputation of our CDA series amps. Our goal was to keep the excellent sonic qualities while adding a state-of -the art balanced input stage (also accepts standard single ended input) and external adjustable gain controls. We've also added a better cooling system, Molex connectors for external LED's, power switch, and gain controls (included). The balanced input stage is one of the finest available and normally only found on very expensive high-end equipment. When using single ended inputs, you can change a jumper to select inverted or non-inverted input as well... useful in some instances. The gain controls included with this kit feature a conductive plastic element for ultra low noise. Our Super D Series amps provide more life-like imaging and sound stage, along with the beautiful smooth tube-like sound we're known for. These amps are powerful, clean, quiet , and transparent. Specifications: • Output: 250 X 2 - 4 Ohm, 125 X 2 - 8 Ohm • Bridged Output: 500W X 1 - Bridged 8 Ohm (Full Bridge) • THD+N, 1W - 1KHz: Better than .02% • Dynamic Range: 101 db • Efficiency: Over 90% • Required Power Supply: +/- 40 Volts DC to +/- 50 Volts DC Accepts Balanced or Single Ended inputs at up to 18 volts. More specs coming soon.
« Last Edit: 14 May 2014, 05:41 pm by Nick77 »
poseidonsvoice
    • 2 channel/7 channel setup
Re: FS: ClassD Audio SDS254 Amplifier Upgrades $385
« Reply #1 on: 8 May 2014, 10:56 pm »
Bump for a great trustworthy honest seller!
Best,
Anand.
Nick77
Re: FS: ClassD Audio SDS254 Amplifier Upgrades $365
« Reply #2 on: 10 May 2014, 03:11 pm »
Rated 7/10 for diy nature but 10/10 for sound. :)
Thanks for looking......
« Last Edit: 11 May 2014, 12:05 pm by Nick77 »
Nick77
Price lowered, figured $200+ in upgrades plus labor. $350 for an awesome sounding amplifier rated @125 watts. Audition more than welcome, this hits way above its price point.
Nick77
Re: FS: ClassD Audio SDS254 Amplifier Upgrades **SOLD**
« Reply #4 on: 22 May 2014, 11:06 am »
I sold the amp to vinayarora and wanted to say overall a very positive experience. He is from India and at first i was very skeptical but found other posts about positive purchases so I decided to respond. All i had to do was mail to his agent here in the US and he takes care of mailing to India. No issues with payment and excellent communication, recommend working with him.  :thumb:
vinayarora
« Reply #5 on: 22 May 2014, 02:34 pm »
Thanks Keith and it was pleasure dealing with you.
--Vinay
