SOLD: Pure I-20 Iphone Dock
0 Members and 1 Guest are viewing this topic. Read 1793 times.
Peter_S
« on: 7 May 2014, 03:43 pm »
SOLD: If anyone is interested, I've got an I-20 with remote available and will sell for $20 plus shipping.  You can use it to extract digital from your iphone (30-pin) and either convert it to analog or provide a digital signal to a DAC.  Google this device if you're not familiar with it.  If you've got an iphone 4x, or a 30-pin ipod touch, or a 30-pin ipad (I haven't tried it on the ipad, do your research), you can patch it into your stereo system using this.  It can then be used as a streaming device or as a digital player for music files loaded on it.
Get some good use out of your 30-pin idevices!!!!
« Last Edit: 19 May 2014, 07:29 am by Peter_S »
geowak
Re: Pure I-20 Iphone Dock
« Reply #1 on: 7 May 2014, 04:04 pm »
Sent you a PM
ccklone
  • The Only Good Head is a Deadhead
« Reply #2 on: 7 May 2014, 04:55 pm »
Hey Now,
If geowak doesn't buy it, I will. Sending PM.
Finest kind,
Chris
paul79
« Reply #3 on: 7 May 2014, 05:34 pm »
Seeing as how you cannot hardly get these anymore, that is a steal!!!
saeyedoc
« Reply #4 on: 7 May 2014, 06:23 pm »
Yea, that an a $10 app and an old idevice and you have a home built Squeezebox!
blownrx7
« Reply #5 on: 7 May 2014, 07:10 pm »
PM sent too. Wishing, hoping...
paul79
« Reply #6 on: 7 May 2014, 10:33 pm »
To further, add an Empirical Audio Synchro Mesh Reclocker to it, and you have a world class digital source for your DAC! I used mine this way, and had to spend allot more to get as good as it was. I still don't think I am much better off sonically, with the exception of being able to play higher resolution files natively.
The Synchro Mesh is stupid good, and using an Ipod with the I20 was sooooo easy. Add your files to the Ipod, dock it, and rock it :)
Charles Xavier
« Reply #7 on: 10 May 2014, 05:22 pm »
did anyone end up buying this
ccklone
« Reply #8 on: 10 May 2014, 05:34 pm »
Hey Now,
I wouldn't mind the opportunity to buy it  8)
Finest kind,
Chris
loving_it
« Reply #9 on: 13 May 2014, 03:10 pm »
interested also
Peter_S
Re: SOLD: Pure I-20 Iphone Dock
« Reply #10 on: 19 May 2014, 05:48 pm »
Well, I clearly priced this a bit low!  In any case, it is gone.  I have no 30 pin devices left to fit it with.
geowak
« Reply #11 on: 21 May 2014, 02:26 pm »
Peter,
Thanks for the I20. Works just fine. For all others out there, I think it can still be bought, but Pure has not made an updated model with the lightning connector. They should!!
