0 Members and 1 Guest are viewing this topic. Read 1929 times.
Hi, you'll need to be able to measure it to get things correct. With that said, if your mains are sealed (?) and are rolling off naturally at ~70 Hz then that's effectively a second order (Butterworth) filter. Adding a second order highpass at the same frequency will turn it into a 4th order Linkwitz-Riley, then set the bass lowpass to 4th order LR.Looking at your arrangement, I'd be inclined however to put the bass-mid crossover up higher. Say... 120 Hz. In that case you can use whatever crossover slopes on both sides. Set the delay on the mains initially to match the physical offset and then measure and tweak...
I had used the distance offset for time in my previous set-up, but had not taken anything into account for the crossover. I guess what I am not fully understanding is the time (phase) lag due to the crossover selection. Shouldn't that lag be added to the difference in distance between the two sections in order to create a correction and have the system in proper phase?
Room modes are generally more forgiving to the frequencies above 100-120 Hz.
Killer rig, but is that Hans Solo cryogenically frozen on your back wall?
