Digital AES/EBU
0 Members and 1 Guest are viewing this topic. Read 1682 times.
guyguay
Digital AES/EBU
« on: 3 May 2014, 12:24 pm »
I Am looking to buy a Bryston Digital AES/EBU 1 meter to match my BCD-1 with my SP3 at 105$
Is it a good cable. Should i pay more to have better cable
thank you
Samurai7595
Re: Digital AES/EBU
« Reply #1 on: 3 May 2014, 01:06 pm »
thank you
It depends...
What's the rest of your system like (e.g. gear and cables).
guyguay
Re: Digital AES/EBU
« Reply #2 on: 3 May 2014, 01:17 pm »
SP3
9BSST2
BCD-1
Monitor Audio Silver Speakers (Will Upgrade)
AC Cable Bis Audio AC AMP and AC20
APC H15 (will Upgrade for Bryston BIT20)
Bis Audio XLR MAESTRO between 9B and SP3
Samurai7595
Re: Digital AES/EBU
« Reply #3 on: 3 May 2014, 02:52 pm »
SP3
9BSST2
BCD-1
Personally, I like the Bryston digital cables.
For your system, why not just stick with BIS Audio?
guyguay
Re: Digital AES/EBU
« Reply #4 on: 3 May 2014, 05:03 pm »
yes but the price of the aes/ebu cable for BIS audio is 400$
not sure if the price difference is for better quality
thank you
So There
  • Brystonized
Re: Digital AES/EBU
« Reply #5 on: 3 May 2014, 05:32 pm »
At James Tanner's recommendation, I bought the Bryston AES/EBU cable to run between my BDP-2 and BDA-2, and I couldn't be more pleased.
Rich
_____________
Whiney Napa Valley
The means — Bryston SP3 | Bryston 6B-SST(C) - L/C/R; 4B-SST(C) - surrounds; 4B-SST(C) - rears | Bryston BDP-2 Digital Player; BDA-2 D/A Converter; Oppo BDP-105 | Paradigm Reference Signature S8 fronts; C5 center; ADP surrounds; S4 rears; two Velodyne DD15 subs | APC S20 | Pioneer Elite PRO-1130
guyguay
Re: Digital AES/EBU
« Reply #6 on: 3 May 2014, 05:47 pm »
Thank you Rich
drummermitchell
Re: Digital AES/EBU
« Reply #7 on: 3 May 2014, 11:38 pm »
I also use the Bryston AES cable.
Haven't tried any other AES cables and no desire to.
Use go through all kinds of speaker cables,IC's,PC's where were talking anywhere from 600 up to 2400
LOL ended back with Bryston IC's,speaker cables and no regrets.
If they diminished the sound compared to the other expensive cabling I would have sold them.
Totally content.
