PEQ question
0 Members and 1 Guest are viewing this topic. Read 1117 times.
ricardojoa
PEQ question
« on: 30 Apr 2014, 12:12 pm »
Hi,
i got a question on peq equalizers. As i understand peq allows a cut or boost of frequencies in a narrow and wide Q. My question is, if the frenqurncy being cut ot boost had a wide Q, does that mean that frequencies above and below the set frequency gets affected as well?
Davey
Re: PEQ question
« Reply #1 on: 30 Apr 2014, 01:01 pm »
Hi,
i got a question on peq equalizers. As i understand peq allows a cut or boost of frequencies in a narrow and wide Q. My question is, if the frequency being cut or boost had a wide Q, does that mean that frequencies above and below the set frequency gets affected as well?
You bet they do.  Parametric equalization is well explained on numerous websites.  Here's a nice, simple example:
http://www.rane.com/pdf/ranenotes/Bandwidth_in_Octaves_vs_Q_in_Bandpass_Filters.pdf
Dave.
ricardojoa
Re: PEQ question
« Reply #2 on: 30 Apr 2014, 02:02 pm »
Thank you for the link.  :)
Russtafarian
  • Typical reaction to the music I play
Re: PEQ question
« Reply #3 on: 30 Apr 2014, 05:55 pm »
Q is what makes PEQ's so tunable and powerful.
Let's say the system sounds a bit zippy.   You could fix this by turning down the treble control (usually a shelf filter @ 10khz).  But that would diminish the sparkle and air in the system as well.
With a PEQ, you can cut by about 6 db then sweep the frequency control to find where the zip diminishes (somewhere between 6 and 10khz).  Then you can use the Q control to narrow the filter enough to tame the zip while preserving the top end sparkle.
Say the next record you play is a 45 rpm Pet Shop Boys dance club remix with so much grating treble energy the local pets flee the neighborhood.  By temporarily widening the Q of your zip filter, the record becomes somewhat listenable through your diamond beryllium magnesium dome-ribbon hybrid tweeter.
andy_c
Re: PEQ question
« Reply #4 on: 30 Apr 2014, 10:44 pm »
Hi,
Yes they do.
Here's an example of the response of a parametric EQ when Q is varied. I've chosen the round number of 10 dB for the boost and 100 Hz for the center frequency, and plotted the results from 10 Hz to 1000 Hz on a log scale. I've varied the Q in a 1, 2, 5 sequence as follows:
Q = (0.1, 0.2, 0.5, 1.0, 2.0, 5.0, 10.0)
The smallest value of Q gives the "fattest" curve, while the largest value is the "spikyest". So you can consider Q to be the "spikyness factor". You can see that the boost area is quite "fat" for low values of Q and becomes much narrower for larger Q values.
Notice also that many of these Q values are way too low to be useful for EQ. They are for demonstration purposes only.
