Phono pre for sale
0 Members and 1 Guest are viewing this topic. Read 728 times.
jimdgoulding
Phono pre for sale
« on: 26 Apr 2014, 08:54 pm »
From Monolithic Sound . .
retail price $399
The PS•1 Phono Stage offers superb sound quality & versatility at an affordable price. The internal design is completely dual-mono, with a creative design to keep signal path components to a minimum. Rear panel DIP switches are used to select settings for resistive load, capacitance, gain and subsonic filter. This flexibility allows for use with almost any line stage and MM/MC phono cartridge.
Specifications:
 Loading Resistance: 47k, 10k, 1k, 100 ohms
 Capacitance: 100pf, 270pf, 370pf
 Gain: 26db, 35db, 44db, 53db
 Power Supply: 16 VAC (included)
 Dimensions: 8.5" x 6" x 2.5"
 Weight: 6 lbs
 Warranty: 1 year parts & labor
Bought it new.  Sounds good.  Very open and detailed.  I have two new ones I'm enamored with and no job.  Best offer.
