0 Members and 1 Guest are viewing this topic. Read 3696 times.
.. transmission lines... Bass rolls off smoothly (if designed correctly) at 6 dB/octave (same as room gain). Port output is in phase with driver... Bob Brines M18-F200
If i were to built a my own enclosure, how should i approach in desing the box tunning? Without knowing the outcome of the end result, there could only be expeculation on graphs.So how do some expert who have built their cabinet have they decided what tunning would be best suited?
The "best" tuning frequency depends not only on the woofer parameters and box size, but also on room acoustics and even on the amplifier.
I'm pretty sure a low damping factor (high output impedance) will alter the frequency response of the woofer. Not a concern with modern SS amps, but with some tube amps it could make a difference.
I still don't get it,what is the damping factor of the amplifier do to system Q of the loudspeaker?
if the loudspeaker sounds different with different damping factors of the amplifier,then we havescrewed up the amplifier!
I strongly disagree with this statement. We simply need to make informed choices about amplifier and speaker pairings. Or if we aren't quite geek enough for that, we need to pay attention to the recommendations of amplifier and speaker manufacturers, who are geek enough.
...back then also the amplifiers were being developed with little more than a resistive load and measure ments were being taken thd df etc..that's what i learned that's what i stick with..
