Sold: Coincident Speaker Technology Super Eclipse III
0 Members and 1 Guest are viewing this topic. Read 4385 times.
Hear Clifford Brown
The Coincident Super Eclipse III is the final version of the original Super Eclipse. This pair, in beautiful natural cherry finish, is the superior $7K version of the SE, with the woven carbon fiber drivers on the mains, and silky smooth Scanspeak Revelator tweeter. They have the optional outrigger legs with spikes. They are 92db efficient at a very flat 10 ohms, which means they pair off with lower-powered tube amps, but I've found them to be an outstanding companion to solid state as well.
They are a full-range speaker with a great low end that also excels at the subtle inner detail of the midrange and highs like only the very best speakers can. They are in very good shape having had only two meticulous audiophile owners. The drivers are perfect and the speakers function flawlessly and sound outstanding. They look almost mint, but do have a few minor nicks which are extremely minor and small, you need to be within a few inches to see them.
These weigh close to 100lbs each, and I have the original factory boxes, but will NOT ship these at this point - If I don't find a local buyer I may consider shipping in the future. For now, this listing is for pickup or delivery / meet in the Seattle to Portland area only. I will audition for active AudioCircle members with cash-in-hand. PayPal is OK-buyer pays 3% and must be verified, and funds must clear before speakers are picked up. Check my over 100 positive feedbacks over the past eleven years on Audiogon.
I am asking $2,800 here on AudioCircle, $3,000 on Audiogon.
The conclusion of Sue Kraft's 2005 review for The Absolute Sound:
“While I found the Super Eclipse to be a more resolving as well as less forgiving speaker than its big brother, it was by no means brutally revealing. In fact, one of the most impressive aspects of the Super was its high level of clarity, smoothness, and sophistication. I’ve owned units costing more—the Dunlavy SC-IV comes to mind—that wouldn’t hold a candle to the Super’s refinement. The high frequencies were as clear and extended as the associated equipment would allow, with no audible smearing. The Super also has a nicely balanced top to bottom presentation, without any obvious humps or bumps along the way.
The Coincident Super Eclipse III will easily outperform its $6000 price tag when it comes to smoothness, clarity, and transparency. Its impressive three-dimensionality, coherency, and midrange sparkle—combined with its bottom-end articulation and dynamic punch—more than make up for any lower-frequency extension limitations. For the tube lover, the Super’s abundant sensitivity is a dream come true. When paired with the likes of the spectacularly musical Mactone, the speaker’s richly detailed and vibrant tonal colors are absolutely stunning.”
Complete review: theabsolutesound dot com forward slash articles forward slash coincident-technology-super-eclipse-iii-loundspeaker-1 forward slash
Specifications:
Frequency Response: 28hz - 35khz
Impedance: 14 ohms (never dropping below 10)
Sensitivity: 92 db 1m -1 watt
Power Requirements: 7 watts - 300 watts
Dimensions: 42" H x 8" W x 16" D
Weight: 96 lbs ea.
Driver Compliment:
Tweeter: 1 - 1" Silk Dome
Midrange: 2 - 5.25" Carbon fiber midrange units.
Woofer: 2 - 8" Paper Treated Woofers
Price: $6,999.00 US/pr.
From the 2008 Coincident web site (very long, probably more info than anyone will read, but here it is):
Drivers:
To build a state of the art loudspeaker requires the use of state of the art drivers. No amount of crossover manipulation or driver massaging will transform inferior drive units into a superior loudspeaker. The Super Eclipse uses only the best tweeter, midrange, and woofers, regardless of the cost. Not only are the individual drivers the most accurate money can buy, but also equally significant is that all the drivers blend seamlessly to create a coherent, almost crossover less sonic presentation. To virtually replicate the incoming signal requires drivers capable of lightning speed and high power handling capability. This mandated the use of the finest available silk dome tweeter and specially created carbon fiber midranges. The desire for realistic weight, impact and low frequency extension dictated the use of very special high mass, large magnet, paper treated cone woofers arranged in pairs.
Tweeter:
The Super Eclipse III incorporates the identical tweeter as used in our reference speaker, the Total Eclipse. This silk dome, specialized version of the state of the art Scanspeak Revelator is a no holds barred quest to offer the finest high frequency reproduction currently available. It uses a powerful double magnet assembly for high power handling capability and very low resonant frequency of 550hz. A vented pole piece and special cavity damping techniques reduces spurious resonances to insignificance. While most other tweeters use flimsy, high resonant front plates made of thin plastic, the Super Eclipse tweeter's front plate is manufactured from thick aluminum. The dispersion characteristic of this tweeter is so wide that even flat frequency response is maintained to beyond 20khz at 30 degrees off axis. Truly incredible performance! The Super Eclipse tweeter is highly detailed, refined, and pure sounding, while at the same time is smooth as silk. The new tweeter's design goals were:
• Maximum dynamic linearity.
• Ultra low coloration.
• State of the art retrieval of outer AND low level detail.
• High sensitivity AND high power handling capability.
A daunting task to be sure, but the critical and commercial success of our Total Eclipse loudspeakers was reflective of our success in achieving these lofty goals.
To quote from a noted and respected audio reviewer on this new tweeter:
"... and that treble ...mahhhhvelous, darling- more open, more extended, more revealing, yet not even the slightest hint of fatigue, brightness or glare even with bad recordings. The titanium tweeter (previously used) would reveal the flaws in a recording in a less, um, merciful manner."
The development of the new tweeter incorporated some very novel ideas:
1. To achieve this new level of resolution required a totally new coating process on the silk dome. It is a highly complex procedure, done by hand and involves multiple coats of a specially formulated compound, which not only increases dynamic linearity but also critically damps virtually all cone resonances at the same time.
2. Furthermore, the double magnet assembly is housed in a uniquely developed chamber that is devoid of any resonances.
3. A completely new magnet system eliminates electrical phase shift.
4. The high gauge, aluminum front plate has exceptional linear directivity controlled down to lower than 2khz.
The end result is a tweeter capable of high frequency reproduction that sets new sonic standards. Harmonically complete, astounding retrieval of detail, precise transient response, maximum dynamic linearity with absolutely no compression or resonances.
Midrange/woofers:
Only the finest 5.25" carbon fiber cone units were deemed appropriate and were therefore selected. Only the most skilled craftsman makes them by hand and only after carefully inspecting each part to ensure the highest quality and absolute consistency. The goal: A loudspeaker without compromise.
Indeed, these drivers are the most expensive units of their type because quite simply, they are the best. The extremely stiff, yet light, cone, (only 9.6 grams), give tremendous bass precision and midrange detail.
To ensure high power handling capability, high sensitivity and a high impedance modulus, holographic imaging, vanishingly low distortion and unrivaled detail retrieval, dual 5" units arranged in a D'Appolito configuration was decided upon.
The D'Appolito arrangement was chosen due to the many inherent advantages of the design (i.e. greater sensitivity and enhanced dynamic performance and power handling capability due to the coupling of the midrange/woofers). However, the endemic drawbacks of this design as previously configured, were formidable and had to be, at the very least ameliorated, better still vanquished. Here is where six months of research and development ensued.
The textbook D'Appolito alignment was plagued by small degrees of lobing in the vertical plane, but severe lobing in the horizontal. After thorough analysis of the mathematical relationships of the driver spacing, it was ascertained that not only is the distance between the midrange/woofers to the tweeter critical, the distances between the midrange/woofers themselves are of fundamental importance. Furthermore, these distances are dependent upon the crossover slope and frequency.
Therefore, what developed was the acknowledgement of the interdependency of the driver size; driver spacing, and front baffles area, crossover frequency/slope. A change of one variable mandates an alteration of another. From myriad computer simulations, mathematical calculations, prototype testing and aural evaluations, what emerged was a totally new approach to the D'Appolito configuration that is responsible in large measure for the sonic breakthrough of the Super Eclipse. (Indeed, this novel methodology is presently the subject matter of a pending patent application).
The summary of these conclusions is as follows:
1. The D'Appolito alignment is optimally applied to midrange/woofer drivers no larger than 5.25" in diameter. Any larger mitigates against the optimum spacing between the midrange/woofers and the tweeter, (as measured from the driver centers).
2. First order crossovers are essential to maintain perfect phase relationships and time constants.
3. The crossover frequency does not have to be as low as previously believed, (typically 2khz).
4. The spacing between the midrange/woofers and the tweeter must be asymmetrical by an amount measured in mm.
5. Flat off axis frequency response requires absolutely no front baffle diffraction effects.
When the design is optimized, as is the case with the Super Eclipse, all lobing in the vertical plane is virtually eliminated and horizontal lobing is minimized to the point where flat to 20khz response is achieved up to 3- degrees off axis. Sonically this translates to a vertical sweet spot that extends essentially from floor to ceiling. Indeed, listen to the Super Eclipses while standing or seated and very little difference will be observed with regard to imaging or tonality. In the horizontal plane, listening while moving from side to side will still provide the listener with superb focus and dimensionality.
Special Features of the Midrange/Woofer Drivers:
1. Precision cast and surface treated carbon fiber cone coupled to a natural rubber surround prevents any sign of midrange resonance.
2. Very large magnet structure for improved sensitivity and transient response.
3. Heavy copper rings mounted above and below the T-shaped pole piece greatly reduces non-linear and modulation distortion and increases overload margins.
4. Very rigid injection molded chassis made from high purity magnesium, keeps the critical driver components in perfect alignment.
The net result is midrange/woofer performance that sets a new standard for detail delineation and imaging precision combines with dynamic realism.
Woofer:
To accomplish the goals of high sensitivity and high impedance, coupled with low frequency performance that is dynamically unrestrained, weighty, impactful, and a seamless blend with the sonic characteristics of the mids and highs, required the use of a pair of the finest 8" woofers money can buy. The woofer chosen for the Super Eclipse uses a huge magnet assembly with a 2" voice coil. A very stiff, specially treated paper cone is almost impervious to cone break up or flexing. It uses a novel long stroke, low reflexion magnesium basket that is so rigid that unwanted movement is totally prevented. The thick yet flexible natural rubber surround effectively dampens the cone and reduces distortion to vanishingly low levels.
The dual woofers are specifically tuned to provide very tight and articulate bass with tremendous impact and dynamic explosiveness.
Enclosure:
To create a loudspeaker with the imaging qualities of a mini monitor while simultaneously providing realistic weight, impact and dynamics of a large speaker mandated the use of two enclosures per channel. Therefore, the tweeter and midrange/woofer drivers are housed in a sealed sub enclosure. This sub enclosure's internal volume has been computer modeled to provide a perfect "Q" of .707. Furthermore, the internal volume of the sealed enclosure provides for the midranges' low frequency roll off point, thereby eliminating the need for a large value capacitor to be inserted into the signal path. The end result is greater signal purity.
The front of this enclosure has beveled edges leading to the drivers to eliminate diffraction effects so that imaging and high frequency purity will not be adversely affected.
The dual 8" woofers are mirror imaged side mounted in a separate enclosure that has an internal volume 8 times that of the top enclosure. The very narrow profile of the system, (a mere 8" wide, chosen to maximize spatial reproduction), is maintained by extending the depth of the woofer enclosure to 16". The side mounting of the woofers also proves highly advantageous in providing flexibility in room loading thus helping to avoid standing wave problems. Furthermore, due to the side firing nature of the woofers, interference effects between the mid and high frequencies and bass are dramatically reduced. This prevents the low frequencies from impinging upon the purity of the mids and highs.
All Coincident enclosures are constructed form the most rigid, non-resonant material we have tested: 1" MDF hardwood. Additionally, all Coincident enclosures are tuned to a sonically benign fundamental resonant frequency of 350hz.
Unique to the enclosure built for the Super Eclipse III is the use of an elaborate bracing scheme to create an enclosure with virtually no sonic signature. The combination of 1" MDF hardwood, sealed sub enclosure for the mids and the tweeter, plus a highly sophisticated internal bracing system puts the Super Eclipse into a category of loudspeaker unique at its price.
Furthermore, internal standing waves have been effectively banished due to the computer designed enclosure dimensions.
In short, Coincident enclosures have virtually no sound of their own. Therefore, the Super Eclipse III' reproduction takes on an open, spacious quality only previously heard in boxless speakers.
Crossover:
All Coincident crossovers are first order designs, (for reasons of sonic purity and phase coherency), utilizing the finest polypropylene capacitors, large gauge air core inductors and metal oxide resistors and are matched to within a 1% tolerance range. The entire crossover is hardwired, eschewing circuit boards or terminal connectors because they degrade sonics and deteriorate over time. All Coincident crossovers are computer designed and then fine tuned by scrupulous aural evaluation.
First order crossovers can only be used with drivers possessing the following qualities:
1.High power handling capability.
2.Smooth roll off characteristics.
3.Wide bandwidth.
The Super Eclipse III drivers are quintessential examples of the above noted characteristics. All the drivers can handle in excess of 200 watts continuous, have no resonances within the audible range and are capable of flat frequency response greater than 2 octaves beyond their crossover points. Additionally, all drivers used in the Super Eclipse are matched to within .1db to ensure absolute unit-to-unit consistency and precision performance.
« Last Edit: 17 May 2014, 05:12 am by Hear Clifford Brown »
Hear Clifford Brown
Bump for lower price
Hear Clifford Brown
Bump
