SOLD, NAD Power Amplifier, 2200. $275.00 shipped, lower 48 only.
0 Members and 1 Guest are viewing this topic. Read 889 times.
bladesmith
  • water quenching steel since 2001....
    • palmer knives
I have a NAD 2200, back from the service shop,  tested, rebiased, new relay switch. About a 6/10, due to age and some blemishes.  Which were there when I bought it. It has been very strong and has more than enough power to push anything.
$275.00 shipped to you,  lower 48 only.
http://nadelectronics.com/products/hifi-amplifiers/2200-Stereo-Power-Amplifier/
« Last Edit: 20 May 2014, 03:08 am by bladesmith »
bladesmith
    • palmer knives
Re: NAD Power Amplifier, 2200. $275.00 shipped, lower 48 only.
« Reply #1 on: 28 Apr 2014, 09:45 pm »
Very powerfull. This amp will drive anything. Rebiased and ready for service.
Bump....
Specifications
Continuous output power into 8ohm * 100W (20dBW)
Rated distortion (THD 20Hz - 20kHz) 0.03%
Clipping power (maximum continuous power per channel) 140W
IHF Dynamic headroom at 8ohm +6dB
IHF dynamic power (maximum short term power per channel) 8ohm 400W (26dBW)
4ohm 600W (28dBW)
2ohm 800W (29dBW)
Damping factor (ref. 8ohm, 50Hz) >100
Input impedance 25kohm / 1000pF
Input sensitivity (for rated power into 8ohm) 700mV
Frequency response 3Hz - 80kHz / +0, -3dBdB
Signal/noise ratio ref. 1W >91dB
ref. rated power >111dB
THD (20Hz - 20kHz) <0.03%
Bridged Mode
Continuous output power into 8ohm 400W (26dBW)
IHF Dynamic headroom at 8ohm +5dB
8ohm 1.2kW (31dBW)
4ohm 1.6kW (32dBW)
PHYSICAL SPECIFICATIONS
Dimensions (W x H x D) 420 x 123 x 370mm
Net weight 12.5kg
Shipping weight 14kg
Power consumption (120 ~ 240V, 50/60Hz) 770W
bladesmith
    • palmer knives
« Reply #2 on: 20 May 2014, 03:07 am »
Sold
