0 Members and 1 Guest are viewing this topic. Read 3127 times.
Use one of bubble level apps on your phone. Mine has a 360 degree level
Charles,Which app do you use. There are several available. ThanksLaura
that's pretty handy. I was going to suggest starting with all feet in the middle of the thread.Do your front to back then side to side.May be good to check your rack and see your starting point too.
If you think of the four points as an "X" instead of a rectangle it should become easier to level anything with 4 legs.Learned that from working on Stock Cars, wedge, crossweight, etc.
