C.A.P.S. V2+ Music Server SOLD!
0 Members and 1 Guest are viewing this topic. Read 2536 times.
Tubeburner
« on: 19 Apr 2014, 03:48 pm »
I am selling the C.A.P.S. V2+ Music Server I just bought from rklein(Randy). I am technology challenged and I do not want to modify this for Wifi since I don't have a LAN line anywhere near my listening room. My fault since I didn't think about needing internet for JRiver. Here is what Randy told me about the build:
The server comes complete with Windows 8 OS. I also have Fedilizer loaded.
Listed below is the parts list for my C.A.P.S. v.2+ build.  It is as follows:
Wesena ITX6 Case (silver aluminum)
Intel DN2800 mt motherboard
Mushkin Enhanced Atlas Series MKNSSDAT60GB-DX mSATA 60GB SATA III MLC Internal Solid State Drive (SSD)
SotM USB card (PCiE)
Mushkin 4Gb DDR3 1066 (2x2)
Includes a standard AC Adapter from Deer Computer Co. for the power.
SOLD
« Last Edit: 30 May 2014, 03:07 am by Tubeburner »
randytsuch
Re: C.A.P.S. V2+ Music Server
« Reply #1 on: 19 Apr 2014, 05:31 pm »
Might want to mention what processor is inside.
Good luck with your sale.
sts9fan
« Reply #2 on: 19 Apr 2014, 05:34 pm »
WiFi can be added pretty easy with no skill needed.
It's a bit spendy though.
http://m.ebay.com/itm/200755616792
sts9fan
« Reply #3 on: 19 Apr 2014, 11:48 pm »
Dual core ATOM processor.
InfernoSTi
« Reply #4 on: 23 Apr 2014, 01:59 am »
This is what I have (except I have a fancy linear power supply as well) and it sounds amazing!  If you have WiFi in your house already, I might suggest adding this little item if you want to keep it:
http://store.apple.com/us/product/FC414LL/A/airport-express-base-station-june-2012  ($75 plus the cost of the ethernet cable, say $15ish)
Just plug that in somewhere within the room that allows you to run a short (say less than 25') ethernet cable and you are done.  JRemote works perfectly so you use that on your phone/tablet (or one of the other remote programs for JRiver).
Perhaps that gives you an easy option…if you considered that and don't want to, no harm no foul.
All the best,
John
Tubeburner
« Reply #5 on: 23 Apr 2014, 02:07 am »
Thank you John. I appreciate the help.
Ernie
loving_it
Re: C.A.P.S. V2+ Music Server Sale Pending
« Reply #6 on: 13 May 2014, 02:52 pm »
PM
