0 Members and 1 Guest are viewing this topic. Read 10498 times.
also looking to up grade my SUT from the Denon AU-300LC to a 1:15 or 1:20 or 1:40 model improving the 103r I am currently using
I'm surprised that you prefer that set up to something like a real wood and Baltic Birch ply rack Mick. I'm sure Newbie is totally confused now
I learned this from two crazy audiophile buddies. I use two Vibraplane air tables for electron microscopes. They work great to keep microphonics to a minimum. Probably limited to a cave situation.
Handsome set up. That wouldn't happen to be an Oracle carbon brush from days of yore ? I still have one, but my little ground wire attachment has sadly passed on.
I've tried many types of materials in different variations but finally found what I think is the ideal combo of looks and sound. Baltic birch plywood boards (better than the oak veneered mdf I used previously) sat on small isolation pads on a solid oak frame. Whatever material/design you choose aim for light but dense and rigid IMO.
Light, dense, and rigid suggests the BDR carbon fiber shelf. Not cheap like Birch, but not crazy expensive like some others. 18 X 14 X 3/4 is about $700, I think. All right, that is crazy expensive.
Sounds good, Rob.Wood all the way! I hate carbon fiber arms ( or what I've heard), so I wouldn't expect much from a shelf. Wood sings... I'm not sure what the hell carbon does...
Have you tried the BDR Carbon Fiber against Baltic Birch friend? My Baltic Birch Ply Rack has proved to be 'the cherry on the top' with regard to my system. It would take some improving upon!
I put sand in the sub cabinets I built, too.
