Bearing cup replacement on a classic?
0 Members and 1 Guest are viewing this topic. Read 1998 times.
akhan13
« on: 17 Apr 2014, 09:03 pm »
Newbie here folks, What a site, treasure trove of info. from fellow audio & sound enthusiasts! My WTT classic is work in progress. So far I have replaced the arm and cartridge and just ordered a bearing cup replacement from dynavector. My old one was bent. Question, has anyone replaced a bearing cup on a classic? Does it pop out from the bottom? Mine is glued from the top. Any thoughts or suggestions will be greatly appreciated.
j beede
Re: Bearing cup replacement on a classic?
« Reply #1 on: 25 Apr 2014, 03:39 am »
Your "classic" was built by Transparent Audio in Standish or Hollis, Maine. These days they are in Saco. I would give them a call to get some advice.
47 Industrial Park Road, Saco, ME 04072
Telephone: (207) 284-1100
akhan13
« Reply #2 on: 26 Apr 2014, 05:17 pm »
Thank you J Beede. Will do. I spoke to Mike Pranka at Dynavector who helped me tremendously. Very knowledgeable on any WTT's.
The turntable has a Dynavector 20x2l cartridge and is hooked up to Rogue Audio M-180's, Cary SLP 2002 pre amp and Harbeth 30's speakers. I am in analogue bliss! :thumb:
SteveFord
« Reply #3 on: 26 Apr 2014, 07:28 pm »
It should just be held in place with a piece of double sided tape.
