Audio/Video Gear and Systems
Owner's Circles
Salk Signature Sound Owner's Circle
jsalk
Listening Distance for SongTower or Veracity ST?
0 Members and 1 Guest are viewing this topic. Read 1314 times.
Chucka
15 Apr 2014, 07:56 pm »
What is the closest listening distance that you would recommend for the Salk Veracity ST or the SongTower SC (or basic SongTower)?
coke
Re: Listening Distance for SongTower or Veracity ST?
15 Apr 2014, 08:38 pm »
I have songtowers with the older ribbon tweeter in a bedroom. There are lots of factors, but in that particular setup I think around 7' is the minimum that sounds good to me.
MikeC78
Reply #2 on:
16 Apr 2014, 10:49 am »
I concur with coke. I have the Veracity ST's and find the particular sweet spot in my room between 7-10', depending on toe. Mine are spaced about 10' apart too.
Owner's Circles
jsalk
