SOLD Sumiko Premier MMT on-the fly VTA-16,
0 Members and 1 Guest are viewing this topic. Read 4741 times.
dvzzz
« on: 15 Apr 2014, 03:07 am »
This tonearm is in excellent condition. Made in Japan by Jelco. $490 + shipping in cont. USA. I cover PayPal costs.
This is Sumiko's best version with on-the-fly VTA-16 mechanism, Sumiko HS12 premium headshell with azimuth adjustment and with premium litz wires and cart screws (that alone is $90 on Needledoctor) and with genuine SOTA pre-drilled armboard ($135 value from SOTA direct). Ready to install on the SOTA turntable. Just plug and play. It was working on the SOTA Sapphire, carefully removed and is now ready for shipping. Tonearm is in perfect shape, no play in bearings that I can detect. Very smooth movements across entire range. Counterweight is smooth. Headshell is pristine.This version has a damping function, reservoir is clean and ready for the damping silicon. The arm height of the FT-4 can be adjusted during play.
I am including Grado XF-3 MM cartridge as-is. It sounds fine with no channel disbalance I can hear. Hours are hard to tell.
Please take a look here for the details and manuals: Premier MMT with VTA-16 on-the-fly mechanism
No scratches or damage of any kind. This is the picture of the actual tonearm, arm board, headshell  and cart.
I will carefully pack the
* Sumiko MMT Premier tonearm,
* SOTA armboard,
* counterweight,
* VTA-16 mechanism,
* mounting collar,
* Sumiko HS-12 headshell,
* Grado cartridge
Overall length: 305mm
Effective length: 239mm
Overhang: 17.3mm
Offset angle: 23 degrees
Mounting distance: 221.7mm
Maximum backswing: 64mm
« Last Edit: 21 Apr 2014, 04:39 am by dvzzz »
