For Sale: Amplification
SOLD SOLD SAudio Space Galaxy 34 Integrated Tube Amplifier - Full remote control
0 Members and 1 Guest are viewing this topic. Read 2470 times.
doak
14 Apr 2014, 03:43 pm »
SOLD
Audio Space has been making high quality tube amplifiers for over 20 years. This less than one year old Galaxy 34 fully remote controlled integrated amp is in excellent cosmetic and operational condition. It is offered with an new production Tung-Sol tubes set with under 100 hours for $995 (new price is $1990).
Also available is a truly premium tube set consisting of 6 old stock RAM LABS labeled Seimens EL34 output tubes, a pair of Psvane MkII CV181-T, and a great pair of old stock Tung-Sol 6SU7GTY (6SL7GT). This tube set costs $550-600. Will sell with this amplifier for an additional $250. All of these tubes are among the very best of their type. The addition of these tubes to the Galaxy EL34 kicks the sound up several notches. Highly recommended.
FEATURES
Rugged stainless steel chassis coated with black paint High quality EI transformers and components Full function remote control Switching between ultra-linear and triode Headphone jack Innovative tube circuitry with choke coil Point to point soldering
SPECIFICATIONS
Input impedance >89k ohm (RCA/Direct In) Output impedance 4, 8 ohm Output power 16W×2 (TRIODE-CLASS AB PUSH-PULL) 32W×2 (ULTRALINEAR-CLASS AB PUSH-PULL) Damping factor >5 Frequency response 20Hz∼30kHz -1dB T.H.D. <1% 20Hz∼20kHz (REF. OUTPUT) Total gain 25dB Input sensitivity 300mV∼600mV S/N ratio >80dB (HUM NOISE<3mV) Channel balance <1dB 20Hz∼20kHz (MAX. VOLUME) Channel separation >60dB (1kHz∼3.3kHz) Vacuum tubes V1, V2, V3, V4: EL34×4 V5, V6: 6SN7 ×2 V7, V8: 6SL7 ×2 Power requirement AC∼115V±5% 60Hz Dimension 330×400×190mm (D×W×H) Weight 50lb. (N.W. ) / 60lb. (G.W.)
Original heavy duty double boxes and all original foam packing for safe shipping.
My Audion feedback under member name "doak" goes back 14 years and is 100%/1146.
Last Edit: 17 Apr 2014, 10:06 pm by doak
