Set speaker distances twice?
0 Members and 1 Guest are viewing this topic. Read 888 times.
jeffreybehr
« on: 18 Aug 2004, 09:14 pm »
Does setting speaker distance in both the DVD player and the pre/pro DOUBLE the time delays?
I'm using an inexpensive Pioneer all-formats DVD player including the 6-channel analog outs.  I listen to a lot of DVD-As, so it makes sense to me to set the speaker distances in the player, so the analog signals are 'timed' correctly.  Should I set them also in the pre/pro?  If I don't, then the signal from other sources won't be timed correctly.
Maybe the pre/pro doesn't apply time delays to the analog inputs?  How about the digital signal from DVD-Vs, ie movies?  Do the time delays double then?
rbrb
« Reply #1 on: 21 Aug 2004, 12:22 am »
Very few Pre/Pro's apply time correction to the analog inputs. What Pre/Pro are you using?
