0 Members and 1 Guest are viewing this topic. Read 8533 times.
So, you 'borrowed' 10' from the 2-car garage? Is it now a 1 car garage, or will it only hold bicycles, in the future???When all is said I done, I definitely want to see updated pictures. Plus, if I am remembering correctly, will Han still be part of the decor?
Housteau,Those V60s must need lots of breathing room.We recently moved and I too had to "recreate" my listening space, although, I had to downsize from 22' X 16-1/2' w/18' cathedral ceiling to 20' X 13' w/10' ceiling and had to move some interior walls to achieve it.
It's quite nice that something new is happening in this circle.
Like you I am always glad to read something from other VMPS owners. I often like to go back in time to reread old postings of years gone by when things were still new and exciting.
I think the room is a very important, if not the most important component to a system.
It's funny, but that has been the biggest concern of people I have told about this, what about the man coming out of your wall? Can you save him? . The answer is absolutely. It was a real trick removing him from that back wall, but I was able to keep him intact. That sculpture is now mounted on the front wall.Yes, loosing one garage space out of that two car garage was a big issue that I had to deal with first. I had lost space for one car plus all that storage. So, part of the preliminary phase was to first add a new carport and build storage cabinets in my front garage. This listening room was built 20 years ago as a detached building from my home. Also due to changes in my insurance policy I needed to build a covered walkway connecting it to my house. Still needing more storage space, I bought one of those prebuilt Derksen workshop /shed buildings I needed to install in my backyard. So, there was a lot of prep work and planning that has gone into this.thereof
Everybody click on Housteau's "gallery" link. I could tolerate that room of his and set up, I imagine.
As to your gear, has that changed? Still the VTL & Eagle amps? Also, what preamp do you use? I'm not sure if I ever read about that?Finally, I just perused your gallery again, and if your old space is any indication, the new room will be phenomenal!!! Also, on the VLA 'subs' (some how, the simple phrase 'sub' doesn't do them justice), they have four actives and one side-mounted passive? Correct? So, since the passive radiator is side-mounted, why the front slot, at the base of the subs? Anything in there? Thanks!
The big plus with the GIK products, particularly the Soffit Traps, is that they absorb lower in the bass then the foam. The foam I had went down to 125Hz; GIK effects down to 50Hz or so. This does make a significant difference resulting in more bass from the music and less from the room - in fact more musical bass.What's so pleasing is how well the RM30s respond to this. I love them!!!
The isolation transformer for my dedicated audio circuit.
O.K., totally off topic I know, but what is with the pink studs? I'm a low voltage electrical contractor in Seattle and I have never seen anything like them.
