FS: Amplifiers - Cleaning House
0 Members and 1 Guest are viewing this topic. Read 7570 times.
macrojack
« on: 11 Apr 2014, 01:13 pm »
I have some pieces laying around which I do not see myself using ever again. Maybe you have a use for some of them. They will ship at your expense from 81521.
- Audio Mirror Single Ended Triode Tube MonoBlocks - Excellent condition. Only a dozen hours use since full factory overhaul. Upgraded capacitors. Many extra output tubes. The amps use two 6AS7 output tubes per amplifier. These are said to last approximately 2000 hours. I have about 20-25 extra output tubes, meaning you will never need replacements again. Before I bought these about 6 years ago, I remember reading that they represented a tremendous value at their retail price of $3200/pair. I have the original shipping cartons so I can get them to you safely. Output is 20 watts per side. They can drive any speaker from about 87 db on up. Best with horns. $1850 for the pair. Would consider trade for NAD M51 DAC or Grace Designs M 903.
- Tim Rawson built class A power amp. Aleph J mini. Estimated output of 20 watts per channel. This stereo amplifier is extremely sweet sounding and best suited to high efficiency speakers. Especially ideal for single driver designs. No original packaging but I think I still have the box it came to me in. Very handsome and well finished amplifier given its DIY origins. This one will shock you. $375.
- ClassD Audio 60 watt stereo amplifier. This is the one that started that enormous thread on AC about Class D kits. Read all 181 pages here:
http://www.audiocircle.com/index.php?topic=76400.0
I have two of these. The first is built in a primitive but functional wooden case. I bought it from Nick 77 here on AC. It was his build and it is pictured on pages 4,5,7 and 8, on the above link. You can actually watch the progress of the build if interested. This is a useful amplifier with performance well above the $250 price.
- Next up is an unbuilt kit of the same amplifier as above. 60 watt stereo class D. All parts and instructions included just as they arrived here. Nothing has been done with this kit. $150. You can buy both for $375 and use them to biamp, to power multiple channels or to wire as monos for 120 watt mono blocks.
- Perreaux PMF 1850 power amplifier. MOSFET design with 185 watt per channel output. Cosmetics are very good on this but there is a problem which would be easily fixed by the confident solderer. The plastic retaining collar around one of the RCA input jacks broke allowing the jack to be pushed inside the chassis. This is a pain if you need to change interconnects. Otherwise, it can be used as is. The amplifier functions now but I would think it wise to repair or replace the jack as you see fit. This one I'm giving away for $300.
While I'm at it, there are some preamps for sale cheap. NAD 114. Looks good, works fine. $120. Kenwood L-O7C preamp. Good cosmetics, noisy pot. From memory, I think it was the volume. $ 150. Also have a sleeper piece- a passive pre I bought long ago. Sound is excellent but has dual volume pots. It's called PSS by David Hum. I know, bad name for a preamp. Anyway, it is compact, very solid, and has 4 inputs and one output. Will take $150.
Then there is a Stan Klyne moving coil step-up. Original box and paperwork. Fully adjustable. You can have it for $350. Also have an NHT PVC passive volume control never used. It has one balanced input and one balanced output. $75.
Just PM me if you want anything listed here or think you might. I'll do my best to answer questions but I've had some of this a long time and may not be able to recall some details.
thunderbrick
  • I'm just not right!
Re: FS: Amplifiers - Cleaning House
« Reply #1 on: 11 Apr 2014, 06:01 pm »
PM Sent
Goosepond
  • Virna!
« Reply #2 on: 11 Apr 2014, 10:08 pm »
PM sent.
Gene
jackthecat121
« Reply #3 on: 12 Apr 2014, 09:19 am »
Any hummmmmmmm from the Audio Mirror monoblocks?
Thanks.
macrojack
« Reply #4 on: 13 Apr 2014, 12:54 pm »
No hum --- not even through high efficiency horns. Have you had that problem with these amps?
macrojack
« Reply #5 on: 16 Apr 2014, 09:01 pm »
Sale pending on the Perreaux PMF 1850.
Also, if there is anything on my list above that interests you, PM me. I just committed to an expensive integrated amp and need to raise money so I don't raise my wife's blood pressure.
autospec
« Reply #6 on: 23 Apr 2014, 01:58 am »
I would be interested in your L07c pre-amp for 100.00.......Let me know  Will Vincent
macrojack
« Reply #7 on: 29 Apr 2014, 11:30 am »
Perreaux PMF 1850 is sold. Thunderbrick swooped in and carried it away yesterday afternoon. First AC member ever to visit my home. Unfortunately he was in the midst of a job related and very rushed cross country road trip and could only stay about a half hour. He's quite the gentleman. It was great meeting him and his boss.
They checked out my system briefly but spent most of the time wrestling with my Akita.
There is a deal pending receipt of payment on the Kenwood LO7c preamp. Lots of interest in the Rawson but mostly insatiable lowballers. It's still available as is everything else. When a significant part of this stuff is gone, I'll list more.
dunross
« Reply #8 on: 3 May 2014, 10:23 am »
I've always been intrigued by these Rawson amps. Is there anything unusual to know about the way it behaves with preamps or is it pretty straight-forward?
macrojack
« Reply #9 on: 3 May 2014, 10:34 am »
I don't really know how to answer this question other than to say that I was very happy with its interface using a Parasound JC2 and a Jeff Rowland Capri. It seemed at home in that company which, given its price and its DIY genesis, says quite a lot.
It is Class A and therefore generates significant heat but, if that creates no problem for you, it represents an opportunity to bring a very high level of performance into your system for a small investment. Naturally, you will want to mate it with high efficiency speakers.
macrojack
« Reply #10 on: 6 May 2014, 11:02 am »
Kenwood L-O7c is SOLD.
macrojack
« Reply #11 on: 16 Jul 2014, 07:24 pm »
Long overdue bump. I really want to move these things out so please consider how you can use them and send me a PM. The Kenwood L-07C and Perreaux PMF 1850 are gone but all the other items are still available.
Prices have softened considerably since this ad was originally published a couple of months back. Contact me if you can use anything here. Will consider selling some of the output tubes separately.
macrojack
« Reply #12 on: 30 Jul 2014, 03:50 pm »
The never built ClassD amp kit has sold.
Still lots of good stuff to be had by a savvy shopper like you. Get in touch.
Mister Pig
  • "when pigs fly"
    • Affordable Audio/Positive Feedback Online writer
« Reply #13 on: 30 Jul 2014, 11:10 pm »
Pm sent on the rawson
macrojack
« Reply #14 on: 20 Aug 2014, 02:05 pm »
Time for a long overdue bump.
Only a few pieces have sold. If you have efficient speakers and a love for single ended tube sound, check out my Audio Mirror mono blocks.
« Reply #15 on: 22 Aug 2014, 04:05 pm »
Can you send pics of the passive pre-amp?
macrojack
« Reply #16 on: 23 Aug 2014, 08:37 am »
Yes - if you provide your email address. I'm too weak in my computer skills to send them through this PM channel, but I do know how to forward photos through email.
The PSS has dual volume controls and toggle switches for input select. Very simple, solid and well made. I have used it for desktop system with active speakers.
« Reply #17 on: 24 Aug 2014, 05:04 am »
Also pics of the NHT passive preamp.
macrojack
« Reply #18 on: 29 Aug 2014, 11:35 am »
The crowd is thinning. I have sold the following pieces:
Perreaux PMF-1850
Kenwood L-07C
ClassD Audio kit
Rawson Aleph Mini J
JRDG Capri
Still have a few other items available, however.
