For Sale Sonore Orbiter
0 Members and 1 Guest are viewing this topic. Read 727 times.
gocubs42
« on: 10 Apr 2014, 05:36 pm »
Works perfectly. I'm going in another direction so here's a chance to get one of these units that are currently out of stock, on backorder, and save some cash! New $900.00 asking $550.00 OBO Shipping not included
Here's the spec's:
PRODUCT DESCRIPTION
The Sonore Sonic Orbiter is an audiophile 24/384 music server with Ethernet input and USB output. The Sonore Sonic Orbiter automatically shows up on Logitech Media Server (LMS) running on your PC or Mac. It also works with LMS running a Vortexbox appliance or a NAS such as the Synology. Just run LMS, load your library, and LMS automatically outputs to the Sonore Sonic Orbiter. It's very simple to use and if you know how to use LMS you already know how to use the Sonore Sonic Orbiter.
STANDARD FEATURES
The Sonic Orbiter supports gapless playback
The Sonic Orbiter supports DSD/DoP pass thru from DoP encoded files
The Sonic Orbiter supports DSD/DoP playback with Vortexbox V2.2
The Sonic Orbiter supports internet radio and streaming radio services
The Sonic Orbiter is powered by an on board, very fast, low noise, low output impedance linear power supply
The Sonic Orbiter power supply is point to point wired by hand with 4 nines silver wire
The Sonic Orbiter between board power supply wiring is mil spec silver plated copper in teflon insulation for low contact resistance and long life/reliability
The Sonic Orbiter is isolated from noise on the network
The Sonic Orbiter has an integrated, high precision volume control
The Sonic Orbiter supports up to 24 bit playback at the following sample rates: 44.1KHz, 48KHz, 88.2KHz, 96KHz, 176.4KHz, 192KHz, 352.8KHz and 384KHz
The Sonic Orbiter plays AAC, AIFF, ALAC, FLAC, MP3, and WAV files from HTTP streams
The Sonic Orbiter is controlled via apps on your mobile device
RECOMMENDED CONTROLLERS and SERVERS
Mobile device controllers
Squeezebox, iPeng
PCM servers
Logitech Media Server (LMS) running on your PC or Mac or NAS (Vortexbox or Synology)
gocubs42
Re: For Sale Sonore Orbiter
« Reply #1 on: 1 May 2014, 04:43 pm »
removed
