Bryston 6BSST2 or 3-ch 9BSST2 / Martin Logan
0 Members and 1 Guest are viewing this topic. Read 1009 times.
justin42
« on: 2 Apr 2014, 06:54 pm »
I'm considering replacing my current amp (Krell Showcase) with a Bryston. Speakers are Martin Logan Vantages + Motif X center. I'd be grateful for any opinions on the 6B vs. the 9B route or the pairing of my speakers with Bryston amps generally. Thank you!
Mag
Re: Bryston 6BSST2 or 3-ch 9BSST2 / Martin Logan
« Reply #1 on: 3 Apr 2014, 12:41 am »
IMO I would go with the 6B SST2 at 500 watts/4 ohms. From looking at the specs for Vantages sensitivity ranges from 4 ohm to 1 ohm. With the 9B you may be short on power at 200 watts/4 ohms if you play your music loud.
95Dyna
« Reply #2 on: 3 Apr 2014, 05:38 pm »
+1
Robin1
« Reply #3 on: 3 Apr 2014, 07:03 pm »
I'm running a 4bsst and a 6bsst with martin logan ascent I speakers
very very happy. electrostats do need the power but with the Brystons.....no problem
Deribas
« Reply #4 on: 24 Apr 2014, 07:45 pm »
Disagree with above posters. I'm running the bigger ML spires and Stage (with surround Scripts) with 5-channel 9bSST.  Never have I seen the amp clip or detected any distortion. Has anyone? 6bsst2 is likely overkill.
