The tube magic you love lives in the power tubes. You won't get the same sound with any SS power amp, in my experience. Even with a tube preamp. If you just can't live with a tube failure every couple of years (not bad odds when you consider the poor quality of current production tubes) then maybe a tubed/classD combo is better for you. Just don't expect it to sound like your M-88.I've had good luck the with Gold Lion tubes. I haven't heard of many failures with those. Maybe some very careful tube purchasing will solve you problems...for a while. But tubes do wear out and fail prematurely sometimes. That's our boat in tube life.
Thanks for the photo. Nice lookin' and it looks to be a fairly simple setup? Is that your DAC under the GR research LGK's? I looked up the specs on the M6i. Very nice.
Here's the proof, JakeAnd yes Ericus, the EE is repaired and sitting in box looking forlorn. Turns out it was simple, a heater tube. I don't really know what that does, there's much about the principles of tube gear I don't grasp. I'll offer it up for sale at some point.Freo, I'd be willing to try my hand at building amps, but don't have a foundation to design/build from, so would be building someone else's design. Can you give or link to more info on what you picture there? Looks wonderful!
Thought I'd update on this topic since I was the one wanting input. I ended up buying a Musical Fidelity A6i. I deliberated on the Rogue, but in the end this deal was hard to pass up. This takes everything that the A3 does and adds to it. I'm using with balanced input, I tried single ended but so far prefer the balanced. Iron grip on bass, layers upon layers of depth in the mids. Revealing without being harsh, it also has some balls if I want to crank it. I'm very satisfied for now and am content to keep this for a while.I haven't ended my relationship with tubes, but for this setup and the time being, this is a wonderful new toy!
