BCD-1 Remote
0 Members and 1 Guest are viewing this topic. Read 2101 times.
1ZIP
BCD-1 Remote
« on: 27 Mar 2014, 10:30 pm »
James or maybe someone else can answer this;
Was the BCD-1 always supplied with a remote?
Robert D
Re: BCD-1 Remote
« Reply #1 on: 27 Mar 2014, 10:31 pm »
Yes Sir Mine was
Regards Robert
Samurai7595
Re: BCD-1 Remote
« Reply #2 on: 28 Mar 2014, 11:23 am »
Yes Sir Mine was
Regards Robert
Same here.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BCD-1 Remote
« Reply #3 on: 28 Mar 2014, 11:45 am »
Hi
Yes a remote was included
ames
alexone
Re: BCD-1 Remote
« Reply #4 on: 28 Mar 2014, 07:15 pm »
Hi
ames
...later models had the BR2 included, correct???
al.
won ton on
Re: BCD-1 Remote
« Reply #5 on: 28 Mar 2014, 07:52 pm »
My br-2 came with the bda-1.
unincognito
    • bryston.com
Re: BCD-1 Remote
« Reply #6 on: 28 Mar 2014, 08:12 pm »
I could be mistaken but only our SP and BCD products have included remotes.  I believe the BDA do not ship with a remote at there retail price, a br2 would be a $350 extra option.
Cheers
Chris
James Edward
Re: BCD-1 Remote
« Reply #7 on: 28 Mar 2014, 09:54 pm »
I have the BCD1, and it was supplied with the BR2 remote. I don't know the intent of the initial post, but this remote is close to useless from an ergonomic standpoint. No one should pine for this thing. The buttons are all the same size, the light function is fickle at best, and I'd keep it's corners away from any nice wood furniture. I bought a Sony learning remote for 20 bucks, and transferred the functions to it.
The BR2 would be great if you needed to hit an intruder in the head. It is a solid hunk of metal.
won ton on
Re: BCD-1 Remote
« Reply #8 on: 29 Mar 2014, 12:21 am »
unincognito             Well mine did,as it was in the same box as the bda-1. Note i did buy the bcd-1 at the same time.
Diamond Dog
Re: BCD-1 Remote
« Reply #9 on: 29 Mar 2014, 02:11 am »
Well that's gotta be worth something, no? It was quite a thing, that BR2 of mine...
D.D.
redbook
  • the music is the blood...........
Re: BCD-1 Remote
« Reply #10 on: 29 Mar 2014, 10:04 pm »
 I love the build of the BR2 remote. It gives the feel of a pro piece of gear and matches well with the general motif of  Bryston equipment in general :thumb:
1ZIP
Re: BCD-1 Remote
« Reply #11 on: 30 Mar 2014, 12:49 am »
My BCD-1 came with a remote specifically for the unit it was called the BCD-1 remote and could control the preamps as well.  Was the BR-2 ever supplied with the BCD-1?
Diamond Dog
Re: BCD-1 Remote
« Reply #12 on: 30 Mar 2014, 03:32 am »
My BCD-1 came with a BR-2 and I suspect I'm not the only one.
http://www.bryston.com/products/other/BR2.html
It was a hefty lil' fella but from an ergonomic/tactile/functionality POV it could have used a little refinement.
D.D.
