15" Alpha vs Beta vs Augie
0 Members and 1 Guest are viewing this topic. Read 4045 times.
Mmaxed
« on: 27 Mar 2014, 08:57 pm »
I am in the planning stages of an OB system.  Does anyone have experience with 2 or more of these drivers to be able to give a comparison?  Looking at flat baffle with two 15s per side.
zimmer64
    • My blog
Re: 15" Alpha vs Beta vs Augie
« Reply #1 on: 28 Mar 2014, 06:21 am »
I am using the Alpha's in the following setup:
Drivers are Fostex FX120 and Eminence Alpha 15
Active crossover using a minidsp 2×4
Asymetrical crossover at 200Hz 2nd order LR and 500 Hz 2nd order Bessel
3DB bass boost; 0.9DB gain high shelve, Q 0.7 @7KHz
Drivers connected in phase
Baffle size is 510 x 950 mm; beech wood 26mm, braced on the back using 40×40 mm beams
Designed using MJK licensed calculation models
Bi-Amplification using my Bob Latino Dynaco ST70 tube amplifier for the extended range driver and my LM3886 chipamp for the bass
http://zimmer64.wordpress.com/2013/12/11/open-baffle-using-fostex-fx120-and-eminence-alpha-15/
The setup sounds really nice, but bass below 40hz is lacking a bit. I read really good stuff about the AE drivers. Different price range though..... http://www.aespeakers.com/drivers.php?driver_id=47
Michael
« Reply #2 on: 28 Mar 2014, 06:39 am »
Hi,
Iam wonder if this AES LO series are different from the Dipole 15??
IMO they seems similar drivers from the same brand.
In what they differs??
embty2002
« Reply #3 on: 28 Mar 2014, 08:01 pm »
Hi,
i had a pair of Alpha 15, but my pair of A&D Audio R1524 are much more better than alpha 15, IMHO.
more clear, controlled bass and cheap price like alpha; i'm playing with a AB power amplifier 125watts channel.
i'm using an active 3 ways system, with foobar + allocator plugin into a Motu ultralike mk1 firewire audiocard.
for the mid-high a pair of Focal PC165 coaxial car audio, with focal neomidium tweeter .
JohnR
« Reply #4 on: 1 Apr 2014, 10:25 am »
Hi,
The T/S specs are different but in a nutshell I understand that they (the LO15) are the TD15M cone and suspension with the underhung Dipole motor. Compared to the dipole15: higher sensitivity, higher FS. Not sure about FR or distortion.
« Reply #5 on: 3 Apr 2014, 10:57 am »
Thanks pal.
