FS: Benchmark DAC-1 w/upgrades!
0 Members and 1 Guest are viewing this topic. Read 671 times.
matevana
« on: 22 Mar 2014, 07:08 pm »
Up for sale is my Benchmark DAC-1 24bit, 192 kHz D to A converter with headphone amp and volume control. This DAC is in great shape and will come with a 14 AWG hospital grade power cable, solid brass isolation feet, a BNC to RCA adapter, and the original bound operations manual.  Works as it should and sounds great.
$650 plus actual shipping. PayPal OK.
For fastest response please send email to: [email protected]
Manufacturers specs:
FEATURES AND PERFORMANCE
• Two Channel, 24-bit, 192-kHz, D-to-A Conversion
• Plays 192-kHz with 52-kHz analog bandwidth
• Direct connection to powered monitors
• Total jitter immunity via UltraLock™ technology!
• 116 dB signal-to-noise ratio @ 48-kHz, A weighted
• THD+N = -107 dB (0.00045%) measured at -3 dBFS, any sample rate, any test frequency
• AES, S/PDIF, and Toslink inputs
• Digital input source-selection switch
• Variable or preset output level controls
• Balanced Low-Z XLR outputs
• Unbalanced RCA outputs
• Automatic de-emphasis for 44.1, 48, and 96-kHz when pre-emphasis bit is set
• Headphone amp = 0.0003% THD into 60 Ω
• Output-off switch position for headphone-only use
• Front panel power and error indicating LEDs
• Internal low-radiation toroidal power supply
• International 120 - 240 input voltage range
• 1/2 wide, 1RU high chassis
• Machined aluminum front panel
« Last Edit: 23 Mar 2014, 08:16 pm by matevana »
