Why did/does the Campion/Alabaster come without remote ?
0 Members and 1 Guest are viewing this topic. Read 2471 times.
Alco
Hello Haider,
I bought a Sonneteer Campion, about 10 months ago, and I love the sound of it.
(also the sober, timeless looks, finish and buildquality are quite exceptional in its price range)
The Campion is driving a pair of Penaudio Rebel 3's and it's a match made in heaven.  :D
The only thing I sometimes miss is a remote, only to adjust the volume.
I wonder why did Sonneteer choose to offer the Campion (and Alabaster) without remote ?
Are there perhaps any sonic benefits in its manual design ?
kind regards,
Alco
« Last Edit: 21 Mar 2014, 12:36 pm by Alco »
haiderSonneteer
  • Managing Director and Founder at Sonneteer
    • Sonneteer, made in Britain since 1994
Re: Why did/does the Campion/Alabaster come without remote ?
« Reply #1 on: 21 Mar 2014, 02:08 pm »
Hello Alco,
We also responded your private email. Thanks you for your question.
The Campion and Alabaster were originally designed as plain and simple amplifiers with just a volume potentiometer as  pre-amp. We then added a higher level input stage for people with 1V line level sources like tape machines and some phono stages.
We did try to add a motorised volume control but it sounded awful. The only way was to have another power supply. This would however change the design considerably and take away a lot of the quality the amplifier has.
Our decision was to leave it alone and design something else. The Orton, though based on having two Campions driving a channel each it was also a ground up design with motorised volume included and hence remote control.
After thoughts can sometimes be detrimental unfortunately. This doesnt mean it is impossible, it would just be quite a lot to get it right. By then we will have designed something completely new. Which is more fun. ;-)
I hope this helps.
Haider
sonneteer.co.uk
Alco
« Reply #2 on: 21 Mar 2014, 04:32 pm »
Hello Haider,
Thanks a lot, for your clear and helpful explanation. :)
I understand now.
regards,
Alco
