0 Members and 1 Guest are viewing this topic. Read 9168 times.
In your price range, you might consider Clearaudio's Virtuoso or Maestro. Previously, I had great experiences with those two cartridges mounted on a VPI JMW 10.5i tonearm.
I would get the Dyna, set it at 100 ohms and you will be in analogue heaven.
... this is only the first cart to play with.
In my readings, I find that most 20xl users load right around 100. TBH, I seriously doubt that I could even hear any diff between 30 and 100. Other golden ears may disagree. But personally, I would not fret about it or get caught up in such minutiae.From Jonathan Valin, TAS:There will usually be a recommended loading value or range of values in the instruction manual. Once again, a suggested cartridge-loading is only that—a suggestion. You do not have to take it as gospel.In my experience, there really is no one “right” answer to this question. The loading of an m-c cartridge depends on which sonic qualities you prefer. In general, loading a cartridge down will tame excessive brightness and/or aggressiveness (and at the same time seemingly make the bass range fuller and more prominent because of the reduction in upper-midrange/treble energy); however, you may pay a small price in dynamic liveliness, presence, airiness, and spaciousness for these sonic gains depending on system context.
Just FYI and FWIW, this reviewer / listener went gaga over the Dyna 20x2L. http://www.audiocircle.com/index.php?topic=124866.msg1316201#new
http://www.sound-smith.com/cartridges/zephyr.htmlI have this with my Classic 2 and I'm happy
I have a Classic 3 with a Lyra Kleos.I would tend to think that at around 800 or so,the Dynavector with that table need not bea "first step" cartridge to be upgraded later........From what I've heard out of that Cartridgeand VPI tables in general, I would tend tothink it could be your forever cartridge......All of my experience has been with the 10.5iarms, you might ask VPI if the gimbal changesanything regarding their cartridge recommendationin that price range, but I don't really see why it would....I would try the cablecompany for a decent discount,or maybe try some independent smaller dealers likeGalen Carol as someone mentioned to try to getas much of a discount as you can..........I don't payretail for ANYTHING......and getting a decent percentageoff gives you more flexibility in selling it with low hoursand changing horses if you're not happy shortly aftergetting it........
