0 Members and 1 Guest are viewing this topic. Read 56662 times.
Another day in the world's longest Ncore build...Ive decided to implement a front switch. Has anyone got any recommendations for something elegant?Thanks!
According to Hypex it is actually 13w.
It depends on if you use the hypex power supplies or some other supply that doesn't provide power for the driver stage. If you use the hypex PS, idle power is 5 W lower.
Well, the data sheet specifies 4.5W with a compatible power supply, 9.5W without. That is of course for the nc400, the SMPS dissipates another 5W.
I still think for longevity it must make sense to turn and on off to some degree. I have to turn them off anyway as my benchmark DAC sends a few volts down the line when it shuts off which can be loud when the power amps are on.
Has anyone used nAMPON? is it 'graceful' or does it induce pops/clicks in the speakers? similarly for the power supply standby?
FWIW I leave my stereo nc400 on 24/7. No power switch. I unplug it if i am going out of town for a few days or if there is a particularly bad thunderstorm. Stays warm to the touch but not hot. I bet if the silicon ray chassis had some ventilation holes in the bottom panel it would stay a lot cooler.
I think Im going to drill some massive holes in the top of my siliconray for that reason. I am not happy with the thermal performance
Do you use either form of standby?
