this improves the sound of the BDA1/2 and/or BDP1/2 ?!?
0 Members and 1 Guest are viewing this topic. Read 1143 times.
alexone
hi, James!
the company (Aqvox) says that this unit would improve the sound of the BDA1/2. true??
http://www.aqvox.de/usb-power.html
the next question would be if it would effect the sound of the BDP1/2 ? would it make sense to use it with Bryston's digital player(s)?
p.s.: the language on this site can be switched between german/english (top left).
thanx,
al.
unincognito
    • bryston.com
Re: this improves the sound of the BDA1/2 and/or BDP1/2 ?!?
« Reply #1 on: 17 Mar 2014, 04:50 am »
Hi Al,
not likley as the BDP already makes use of a low noise linear power supply,  this seems like its made for a traditional desktop computer.
Chris
alexone
« Reply #2 on: 17 Mar 2014, 11:21 am »
ok, Chris. thanks.
the same for the BDA-1? (i guess yes...)
al.
unincognito
    • bryston.com
« Reply #3 on: 17 Mar 2014, 08:41 pm »
ok, Chris. thanks.
al.
If you where using the BDA-1 with your computer instead of a BDP then that is where this is applicable, with that said i still wouldn't use one.
Chris
alexone
« Reply #4 on: 17 Mar 2014, 08:50 pm »
Chris
...do you mean that you wouldn't use an Aqvox or do you mean that you wouldn't use a computer? :scratch:
al.
