Interesting concept Danny do you think it will work?
0 Members and 1 Guest are viewing this topic. Read 1338 times.
jcotner
I don't see how this little driver could do what they claim or maybe I don't
understand the claim. What do you think Danny? Is this driver worth
the time of day? Interesting concept. Sure a lot of Xmax for a 3" driver.
http://www.parts-express.com/tang-band-w3-2052s-3-neodymium-subwoofer--264-927
charmerci
Re: Interesting concept Danny do you think it will work?
« Reply #1 on: 16 Mar 2014, 06:15 am »
"Subwoofer" is a misnomer. They say it only goes down to 50hz. It should be micro woofer.
vlad335
« Reply #2 on: 17 Mar 2014, 12:33 pm »
With 78db sensitivity. No thanks.
Danny Richie
« Reply #3 on: 17 Mar 2014, 10:08 pm »
Just a driver for a limited application.
Maybe a small desktop system using four of those little drivers and something else above it might appeal to some. You'd just about have to use four of them to get the sensitivity up to 84db with one watt. The box won't be all that small anymore though.
Maybe there are some car audio applications with real limited space issues that would allow the use of a bunch of them.
