Hello all This here is my first post, so let me give myself a quick intro..
My name is Billy D and would say I am a audio nut just as you are. only I really don't know much in the speaker and 2 channel tube amp stuff to start up my own listening room.
I have a pretty well laid out headphone rig, So I am good there, but I really want to buy some cheapo but decent sounding floorstanding speakers and a nice little but cheap tube amp. If I listen to it enough and get into it enough then I'll buy better later on. before I do that I need to prove to myself I will actually use it enough to justify sinking loads of money.
what I have so far for the rig,
NAD 542 cdp, I should be upgrading this in about 6 months to a meridian GO8 or a Wadia 302.
Ray samuels hr2 headphone amp/preamp, This is my main headphone amp but I will use it as a preamp with the speaker rig..sounds very nice as a preamp.
what I need,
floorstanding speakers, something not to big but not to small. I really want the least exspensive I can get..just to start out with. anything up to $500 is good for now.
tube amp, I need a cheap but decent sounding tube amp, I was looking at jolida's but I am wandering were I can get something even cheaper?. like I said if I use this stuff enough I will upgrade later.
specs::
room is 12x12
tube amp does not need to be a million watts, just something to start out with.
listen to frank sinatra, andrea Boceilli mostly, the headphones can handly any other type I listen to
thank you all and its good to be on the boards..I plan on sticking around here for a long time.
