0 Members and 1 Guest are viewing this topic. Read 8185 times.
Hi,I've rolled quite a few 6sn7s in my Supratek pre. My favourite budget tube is Tung Sol 6sn7gtb. They punch way above their price, at least in my system.
I've been using old stock Tung Sol tall bottles in my 99. I like them a lot. The 6SN7 in general is not the quietest tube so you'll have to have them screened for noise from your tube monger.http://tctubes.com/Tung-Sol-6SN7GTB-tall-bottle.aspxTC also has a matched pair for $114. The tubes from TC are fully Amplitrex tested and have noise ratings. You might send them an email requesting lo noise 6SN7s and see what they recommend.
Good idea. Btw do the tall bottles fit into rogue 99 ?TxTom
Raytheons are on the right side of the preamp and Tung-Sols in the left. I THINK THEY SAY THE TUBES ON THE RIGHT SIDE OF the 99 AFFECT SOUND FAR MORE THAN THOSE IN LEFT POSITION. DID YOU TRY THE TUNG SOLS ON RIGHT SIDE? I have tried just about every tube combo and loved the Black Treasure CV181-Z, but they did not last very long for the $$.(6 months) WOW. 6 MONTHS AT THAT PRICE, THANKS FOR THE WARNING. NO MATTER HOW GOOD I WILL NOT BE BUYING THESE TUBES!I also invested in Herbies tube dampers and they made a difference.I DON'T KNOW WHAT THESE ARE BUT YOU TWEAKED MY CURIOSTYThanksTom
I use Sophia Electric 6SN7 tube, grade B I think which I paid $60 each for on their periodic sale. I have an Audio Electronics AE-3 Mk II. WHERE DO YOU BUY THE SOPHIA'S? THANKS
No problem with the Tung Sols. BASED ON CURRENT RECOMMENDATIONS, SO FAR TUNG SOLS TOP my list.BTW, have you lowered the gain setting on the preamp? That should affect the noise level of those noisy tubes.I HAVE IT ON THE 2ND LOWEST SETTING MOST OF THE TIME. I Could try the Raytheons again in the lowest setting. However it would be limiting if they were only noise free in the lowest setting.BTW apart from having to adjust the volume levels higher to compensate, does the lower gain setting on pre amp have any intrinsic SQ difference to the higher settings?txTom
Sylvania brown base JAN WGTA6SN7 is what I used in my Rogue Tempest integrated which is basically your pre with an amplifier section added. Contact Paul Lindemann at [email protected].
http://www.thetubestore.com/Tubes/Northern-Electric/Northern-Electric-6SN7Same as the Sophia 6sn7.... Both come from TJ Fullmusic. Dwight
