Auralic Vega Dac, can it benefit from a USB to spdif converter?
0 Members and 1 Guest are viewing this topic. Read 1873 times.
Vangelis
I read a lot of discussion regarding the Vega being used as a preamp but see nothing about owners using USB to spdif converters, I would appreciate it, if someone could tell me why? It would seem that with all the excitement over these converters, they would used by Vega owners.
jarcher
  • It Just Sounds Right
From what I can tell the Auralic Vega has a very good USB input (i.e. supports any format, hi-rez or not).  So there probably isn't much of a need to use an external USB - SPDIF convertor between a computer & this DAC : in fact, the results may be worse.  In my case I only use one because my mac mini is my server, the toslink optical is inferior to the USB, and my DAC (a Bel Canto 1.5) doesn't have the most advanced USB input (it's not asynchronous & doesn't support the highest resolution formats).
I think USB / SPDIF convertors are a stop gap product that will start to disappear as most new DAC's have USB 2.0 asynchronous inputs that support all the way up to 24 / 192 (and in some cases higher - like the Auralic Vega).
santacore
The Vega has a fantastic USB input! Personally I see no need to try an external converter when the internal is of this quality.
