Tortuga LDR3x Passive Preamplifier
0 Members and 1 Guest are viewing this topic. Read 1304 times.
ClefChef
« on: 12 Mar 2014, 02:38 pm »
Tortuga Audio LDR3x passive LDR preamplifier with HiZ option. It uses pairs of microchip controlled Silonex LDR's to achieve the best in signal attenuation with perfect balance. It was assembled into high quality aluminum chassis using Tortuga LDR3x board, high quality RCA connectors, silver/teflon signal wire.
Preamp has 3 inputs and 1 pair of outputs. All functions are controlled by remote as well as front panel rotary encoder: Power On/Off, Volume, Balance, Mute, Input Select. Unit can also be controlled via Apple Remote.
This preamp sounds absolutely incredible in front of SET tube amp - amazing transparency with perfect balance.
Listing includes the preamp, remote, and 12V power supply.
SOLD
« Last Edit: 17 Mar 2014, 01:13 am by ClefChef »
roscoeiii
Re: Tortuga LDR3x Passive Preamplifier
« Reply #1 on: 12 Mar 2014, 05:05 pm »
So via the remote it looks like there is also balance control. Is that correct?
ClefChef
« Reply #2 on: 12 Mar 2014, 05:12 pm »
Correct. I added function descriptions in the ad.
WireNut
« Reply #3 on: 12 Mar 2014, 06:56 pm »
That's a good deal.
