FS: Dunlavy VI
0 Members and 1 Guest are viewing this topic. Read 4281 times.
reactor
FS: Dunlavy VI
« on: 9 Mar 2014, 03:51 pm »
Dunlavy VI in nice condition. Selling them because I am moving my gear into the basement and the VI's won't work in that small space. In addition to the speakers, I have a spare matching set of drivers. $8800.00 US
I will crate them if necessary for shipping.
Re: FS: Dunlavy VI
« Reply #1 on: 9 Mar 2014, 07:21 pm »
It looks a Duntech 2001; :thumb:
WolfsongAudio
Re: FS: Dunlavy VI
« Reply #2 on: 9 Mar 2014, 09:26 pm »
Location?
reactor
Re: FS: Dunlavy VI
« Reply #3 on: 9 Mar 2014, 10:52 pm »
Pembroke, Ontario. 1 hour north of Ottawa
polyglot
Re: FS: Dunlavy VI
« Reply #4 on: 15 Mar 2014, 03:19 am »
If you have the right room for them (reasonably well damped and best along the long wall) and don't mind their size/wight, be prepared to be very pleasantly surprised! One of the best and true full range speakers, designed in the late 90s.
They are very similar to the Sovereign 2001 which uses Dynaudio drivers in stead of Vifa and different caps in the xo. Never had them side by side to hear the difference.
reactor
Re: FS: Dunlavy VI
« Reply #5 on: 15 Mar 2014, 01:50 pm »
The VI's are quite a bit bigger than the 2001's. The VI's have 15" woofers and are about 580lbs a piece as opposed to the Soverein's that come in at about 280lbs.
I don't want anybody purchasing a speaker they think only weighs half of it's weight. They could be in for a suprise.lol
playntheblues
  • D-Sonic, Mola Mola TamBagui, Tekton DISE
Re: FS: Dunlavy VI
« Reply #6 on: 6 Apr 2014, 02:06 pm »
What are the specs on these bad boys?
Steven Stone
Re: FS: Dunlavy VI
« Reply #7 on: 6 Apr 2014, 03:00 pm »
A review can be found on the Stereophile site. I still have my Cherry finished pair...
playntheblues
Re: FS: Dunlavy VI
« Reply #8 on: 8 Apr 2014, 09:35 pm »
DS-21
Re: FS: Dunlavy VI
« Reply #9 on: 14 Apr 2014, 01:40 am »
GLWS, and safe packing. Do not envy the movers who will be required to move these things. I don't think I've ever stood next to a larger loudspeaker.
blownrx7
Re: FS: Dunlavy VI
« Reply #10 on: 14 Apr 2014, 12:33 pm »
From Stereophile review  Published: Aug 24, 1996:
Full-range, floorstanding loudspeaker. Drive-units: two 15" long-throw paper-cone woofers, two 8" long-throw paper-cone woofers, two 5.5" plastic-cone midrange units, and one 1" silk-dome tweeter.
Frequency response: 25Hz-20kHz, ±0.5dB (approx. -3dB at 20Hz). Acoustic phase response: less than +1 degrees, -2 degrees, 100Hz-10kHz. Sensitivity: 91dB/W/m (2.83V RMS). Nominal impedance: 5 ohms. Minimum impedance: 3 ohms. Maximum impedance: 7.5 ohms (including bass resonance).
Radiation pattern: symmetrical in both vertical and horizontal planes. Low-frequency damping: Q = 0.6 (with initial rolloff of 6-8dB/octave). Crossover design: minimum-phase type (6dB/octave) compensated for driver response anomalies and resonance/phase variations. Harmonic distortion: less than 0.3% for an spl of 90dB at 1m for all frequencies above 40Hz. Power handling: approximately 250W peak for 10ms.
Serial numbers of units reviewed: 113-A/B (listening), 130-B (measurements).
Dimensions: 78" H by 18" W by 33" D. Weight: 530 lbs each. :icon_surprised:
Finishes available: light or black American Oak, Dalwood Rose, and Dalwood Teak (other finishes, including cherry, available by special order; Santos Rosewood available at additional cost).
Price: $24,995/pair. Warranty: 5 years limited. Approximate number of dealers: 35.
Manufacturer: Dunlavy Audio Labs Inc., P.O. Box 49399, Colorado Springs, CO 80949-9399. Tel: (719) 592-1159. Fax: (719) 592-0859. www.dunlavyaudio.com
