FS: EMPIRICAL AUDIO MONOLITH 12VDC BATTERY SUPPLY!!
0 Members and 1 Guest are viewing this topic. Read 843 times.
paul79
$650 shipped CONUS!  Any form of payment is fine. http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CCQQFjAA&url=http%3A%2F%2Fwww.empiricalaudio.com%2Fproducts%2Fmonolith&ei=EHobU53CNbOl2AXCvoGwAQ&usg=AFQjCNGDqJPSnUtgD7TTsXfiibS9KU3jEw
This is one superb battery supply. I truly do not believe there is a better 12V battery supply out there. Nothing like it.
I used this with an Empirical Audio Synchro Mesh with fantastic results. It even bettered my DAC's supply in that application.
It will run just about anything that requires 12VDC. Only limiting factor is the AC Adapter/Charger, which is 5.5 amps, so 30W.
I realize this may be a tough sale as Steve has the new Dynamo, exclusively for his customers that purchase his products, but if you are looking to run something else that requires 12V, it does not get much better than this (Chord Qute?). I was so happy with it running the Synchro Mesh, I did not feel the need to upgrade to the Dynamo. It is that good.
Absolutely flawless, original packing/box included.
If the buyer wishes to use this supply for anything with a different DC plug, one can easily be made. I can do this as well if one does not feel froggy.
Thanks for looking!
paul79
Re: FS: EMPIRICAL AUDIO MONOLITH 12VDC BATTERY SUPPLY!!
« Reply #1 on: 14 Mar 2014, 10:34 pm »
Bump!
