Upgraded pulley kit
0 Members and 1 Guest are viewing this topic. Read 1848 times.
ebuzz
Upgraded pulley kit
« on: 7 Mar 2014, 11:55 pm »
I've heard there is a simply and relatively inexpensive upgrade kit for the pulley so you can ditch the old rubber belts.  Where would one get one of those?
Triode Pete
  • www.TriodeWireLabs.com
    • Triode Wire Labs - Affordable Audiophile Cables
Re: Upgraded pulley kit
« Reply #1 on: 8 Mar 2014, 12:37 am »
I'm interested too, for my WT Reference!
Pete
threadkiller
« Reply #2 on: 8 Mar 2014, 06:25 am »
Send Mike Pranka at Dynavector USA an email.
He usually has them in stock.
threadkiller
« Reply #3 on: 8 Mar 2014, 06:27 am »
ebuzz
« Reply #4 on: 12 Mar 2014, 06:56 pm »
Sent email 3 days ago, no response
threadkiller
« Reply #5 on: 13 Mar 2014, 01:51 am »
Probably busy...
threadkiller
« Reply #6 on: 13 Mar 2014, 01:55 am »
Oops, I'm blind ( yet not deaf like some on here)
I might have fouled you up, it's [email protected]
If you did use the correct one instead of my botch, he 'll get to you.
ebuzz
« Reply #7 on: 13 Mar 2014, 01:57 am »
I didn't, but will now. Thanks
