0 Members and 1 Guest are viewing this topic. Read 4050 times.
The American version will sound better (better pickups) and certainly will hold its value. The Mexi version will decrease in value rapidly.Wayner (I love Telecasters).
It's important not to get caught up in expensive guitars, especially when you're starting out. It's easy to get it in your head that you'd be able to play better with the $2,000 model than the $300 one. The more expensive models of usually have better parts, build and quality control whereas the cheaper guitars are more random, with some being garbage, but others being just as good as anything available.I have both expensive & inexpensive guitars and while my Gibson/American Les Paul Classic is my favorite, I have a $200 Ibanez that I bought casually and it's turned out to be fantastic as well. Of course, if the American made instrument is within reach and he likes it, that's great. It'll have the added benefit of increased pride of ownership.There are so many variables, including whether the guitar is set up properly and the way he likes it. What really matters is that he go to a store and play the guitars until he finds one that he doesn't want to put down. The guitar will choose him.
I figured on resale value alone it's the better deal.According to my son, it sounds and plays better too. I was just confused, Fender has so many models that range from $250 for Chinese to thousands of dollars for a top American piece.I don't know where this one is in the model range. It looks like this http://www.fender.com/guitars/stratocaster/60th-anniversary-1954-american-vintage-stratocaster-maple-fingerboard-2-color-sunburst/ but I am sure it is not over $3 g's.
I'm not a guitar player, but I've played the drums for fifty years. Every musician that I've known will tell you the same thing. Never buy an entry level instrument and always buy the best instrument you can afford. It makes a difference. You'll play better, right off the bat and new stuff will come to you easier.Doc
Did he get it?
Lets hear him give it a rip.
