FS: NOLA Boxers - Mint - Low SS#
0 Members and 1 Guest are viewing this topic. Read 2212 times.
fejnomit
« on: 26 Feb 2014, 05:02 am »
Offering a near-mint pair of Nola Boxers in true piano finish cherry wood.  Serial numbers 108 & 110.  One speaker has a hair-line scratch on the bottom.  Other than that, they are flawless.
http://www.nolaspeakers.com/reviews/AVMAX/AV%20MAX_Nola%20Boxer.pdf:
The Boxer is a 2-way stand-mounted monitor built to Nola standards throughout. It incorporates a low-mass 6½-inch bass/midrange driver with a laminated pulp cone for low coloration and high speed. The high frequency driver is a high-resolution silk dome tweeter with smooth extended response. In addition, a diffraction ring is utilized. The bass driver is loaded by a rear firing twin-flared port for low distortion and noise. Although the main priority here is the best possible mid-range quality (as in all Nola speakers), the bass response has been extended to 44 Hz in order to provide a full range sound. Rear connection is by a pair of high quality all metal gold-plated 5-way binding posts. These connectors are fixed directly to the cabinet, thereby omitting the sonically deleterious effects of plastic connection plates often used.
The all-important crossover is a shallow slope design with excellent phase characteristics. The construction employs only point-to-point hand wiring of very high quality components. Capacitors are 630-volt high purity polypropylene types and only air core inductors are used. Resistors are close tolerance 2% metal types.
Wiring is proprietary low-loss oxygen-free copper. The crossover also incorporates a shock-isolation system in order to minimize the effects of vibration for a cleaner sound. The 90dB sensitivity combined with an 8-ohm impedance makes the Boxer easy to drive.
The net result is a wide range dynamic transducer that is accurate but is also truthful to the music. The sound stage is very large and "open", yet has excellent focus. The low distortion provided by the Boxer means that long listening sessions are possible without fatigue.
I am the second owner.  Liquidating my listening room to pay for house repairs.  Asking $1399.  Buyer pays shipping and any fees associated with the transaction.  Thanks for looking.
mnilan
Re: FS: NOLA Boxers - Mint - Low SS#
« Reply #1 on: 1 Mar 2014, 12:41 pm »
Money sent via PayPal...
Mike
