FS: Allnic H3000 LCR Phono Stage
0 Members and 1 Guest are viewing this topic. Read 2264 times.
fejnomit
« on: 26 Feb 2014, 12:15 am »
Asking $5999.
I am the second owner.  Built in 2009.  Comes with new voltage tubes, plus the old set which are still in great condition; also new 7788 tubes – Amperex, the sweetest of the E810F family; and a new Tung Sol 5U4G rectifier.  Selling due to changing commitments.  I am selling off my entire main analog front end.  Please see my other listings for a great turntable, arm and cartridge.  Rated 8/10 just to be safe.  Unit is in immaculate condition.  Comes with double-boxes, original manual and power cord.
Highlights of the H3000 include:
LCR equalization.
Patented gel damping for the tube sockets.
Front panel input selector with choice of 4 tonearm/cartridge inputs.
RCA and XLR output.
Outboard power supply, tube rectified.
User selectable 33db, 26db, 28db or 32 db gain from the hand-wound transformers.
Resistive + gain on the fly allow 16 different loads for all four inputs.
MM and MC can be used at the same time.
Specifications:
Frequency (RIAA) : 20Hz ~ 20kHz (±0.5dB)30Hz ~ 15kHz (±0.3dB)
Voltage Gain : +40dB (1kHz) MM +72 dB (1kHz) MC
Input Impedance : MC up to 117 ohms, MM 47k ohms
Maximum Input Voltage : 20Hz / 10mV(MM, non-clipping) 100Hz / 50mV1kHz / 220mV10kHz / 690mV
THD (Total Harmonic distortion) : less than 0.3% (1kHz output 1V)
Output Impedance : 200 ohms
S/N Ratio : -85dB (CCIR, 1kHz)
Tubes : E810F × 4, 7233 × 2 (A.V.R), 6485 × 2 (A.V.R)
Dimension:
Main Amp : 430mm(W) × 350mm(D) × 173mm(H)
Power supply : 170mm(W) × 275mm(D) × 118mm(H)
Weight:
Main Amp : 15.7kg/ 35 Pounds
Power supply : 6.0kg/ 13 Pounds
Power Consumption : 80W /120V/220V / 60Hz
