Homeworx or IView OTA HD Recorders
0 Members and 1 Guest are viewing this topic. Read 2403 times.
Doublej
« on: 24 Feb 2014, 12:17 am »
Is anyone using a Homeworx or an IView PVR for recording Over The Air broadcasts? If so are you how is it working out? Are there other units that I should be considering?
RCN just tacked on another $6 to my bill for Broadcast TV and Sports Programming Surcharges. I am ready to cut the cord but need to convince my wife that she'll be OK without Tivo.
youravhandyman
Re: Homeworx or IView OTA HD Recorders
« Reply #1 on: 27 Feb 2014, 03:23 pm »
Doublej,
Let your wife rejoice, Tivo has 2 models available that accept OTA antenna input.  So with that and your network connection you should be able to watch just about anything but possibly a few days delayed.  Yes, you would still be paying Tivo for their service, but $15 in comparison to your entire cable bill has to be easier on the wallet.
http://www.tivo.com/discover/antenna
Matt
Todd Willhoit
« Reply #2 on: 27 Feb 2014, 04:28 pm »
I have not used either of the models you mention.  I did not spend much time looking at the specs online, but it appears that they are converter boxes with basic recording capability (no schedules, etc.).
I recommend you look at the Channel Master DVR+.  More expensive than Homeworx or IView, but less expensive than Tivo.  Add a USB hard disk of your choice, set the schedules, and go.  It is easy to use and the picture quality is excellent.
http://www.channelmaster.com/Products_s/329.htm
Doublej
Re: Homeworx or IView OTA HD Recorders - UPDATE
« Reply #3 on: 15 Mar 2014, 01:44 pm »
A friend of mine loaned me his Homeworx box. Works fine. Basic looking interface. TIVO has nothing to fear. You can't schedule recording more than 7 days in advance and you can't say record all episodes of a given show on a given channel. EPG typcially gives you only a one day forward looking view of upcoming shows.
For me it's a non starter. I need something more robust where I can say record all episodes of X.
Todd - How's the program guide and recording capabilities of the Channel Master DVR+?
Next up is to understand how MythTV works. From an old Youtbube video it looks pretty robust.
Todd Willhoit
« Reply #4 on: 15 Mar 2014, 06:59 pm »
The Channel Master DVR+ has a nice program guide.  Once populated, it looks forward two weeks.  It records two programs at a time and can play/pause either of these programs during recording.  If no recording is scheduled, pressing pause while watching a channel results in buffering up to two hours of material for that channel.  This is convenient for grabbing a snack, answering the phone, etc.
I added a splitter to feed both the TV and DVR+ so I can watch a third channel while recording two on the DVR+.  Picture quality is excellent.
I am using a 1TB HDD I had laying around.  I think it is a Samsung F1, but I am not certain without looking.  If I remember correctly, I read that 1TB will hold up to 160 hours.  Color programming, as one would expect, appears to take more space than black and white.
I will say that my unit had an issue rendering it unable to boot.  It was repaired under warranty.  The first sign of the problem was when it froze during playback of a recording.  Now that it has been repaired, I have had it freeze again.  I have not had time to investigate, but it may be that the hard disk is at fault rather than the DVR+.
It isn't perfect, but it beats a VCR, is less expensive than Tivo, and is free of monthly fees.  One down side is that the current firmware doesn't permit recording "all programs with the same name" on a fixed channel.  It will record programs with that name on any channel.  For example, locally This Old House airs Saturday on 8.1.  The same episode airs again Sunday on 8.2.  The DVR+ records both episodes, wasting HDD space and my time deleting the copy.  Hopefully this will be corrected in a future update.
There is an informative Channel Master DVR+ Owners Thread on avsforum.
I tried the MythTV route and had issues getting it configured.  In the end, I realized that if it took that much time for me to configure and maintain, it would likely be a bigger problem for others in the house.  I'm sure it has its advantages, but at some point I get tires of fooling with things and just want them to work.
Todd
