DVD audio extractor
0 Members and 1 Guest are viewing this topic. Read 2429 times.
PETE6737
  • Revel 2 channel
DVD audio extractor
« on: 23 Feb 2014, 11:45 pm »
Hello all
How do I get the songs in the file in order as on the album? For some reason they are alphabetically listed. Thanks, Pete
dminches
Re: DVD audio extractor
« Reply #1 on: 24 Feb 2014, 01:01 am »
Hello all
They shouldn't be.  When it reads the DVD-A they don't show up in order?
Have you tried downloading the meta data?  That may sort things out.
PETE6737
  • Revel 2 channel
« Reply #2 on: 24 Feb 2014, 01:10 am »
In the program they are correct, when they are in a file on my computer they are alphabetical. I can't find a way to not sort by alphabetical.
ted_b
« Reply #3 on: 24 Feb 2014, 01:45 am »
Show us an example (screen shot).  I would think that the track number, or at least chapter number, would be the unique identifier (before tags are added, so like 01-Title 1 chapter 1, 02-title 1, chapter 2 ) so sorting them should be by track number.  ALWAYS include track number in your metadata rules.  Whenever I rip or extract anything from a disc (CD, DVD, DVD-Audio or SACD) I always have [track #] - [artist] - [album] - [name] at the very least.  Then, as a byproduct,  simple sorts are always in track order.
PETE6737
  • Revel 2 channel
« Reply #4 on: 24 Feb 2014, 05:47 am »
Okay I looked at the files ripped from DVD Audio extractor and I found the problem to be in the numbering. The files either had no numbers or they were all title 1.  A little time renaming the titles to include chapter numbers fixed it. Thank you!!
I have been ripping CDs with Dbpoweramp with no problems. I am ripping to Flac with lossless level 5.
I am getting an iPad mini to control the Oppo bdp105. I hope I will not have any issues with the Oppo app and that the files show up correctly. They are fine now with the HD attached to the Oppo with no glitches. Thank you for the assistance
PETE6737
  • Revel 2 channel
« Reply #5 on: 26 Feb 2014, 10:18 pm »
Maybe I am missing it, but is there a way to use or add album art?  Thanks in advance. I'm well on my way to being discless! - Pete
dminches
« Reply #6 on: 26 Feb 2014, 10:55 pm »
I use Tag&Rename for all that stuff.  Highly recommended.
PETE6737
  • Revel 2 channel
« Reply #7 on: 27 Feb 2014, 12:52 am »
Great! Thanks again!
