Mps-2 Powersupply
0 Members and 1 Guest are viewing this topic. Read 823 times.
Xinon
Mps-2 Powersupply
« on: 23 Feb 2014, 07:32 am »
I want to change the voltage on my Mps-2 powersupply to 240V.
I remember from last time I did it that its and easy job, just change place of the grey and white cable coming from the transformer. What I dont remember is what cable, grey or white, is nearest to the black wire for it to be 240v . On the box of my Mps-2 it says 220v, but inside powersupply someone wrote 240v with a marker.
I have changed place on the picture below, but not shure witch is correct for 240v version.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Mps-2 Powersupply
« Reply #1 on: 23 Feb 2014, 11:09 am »
Hi
There may be more to it than that in terms of fuse sizes as well as some resistors - I would check with Mike - [email protected]
james
Xinon
« Reply #2 on: 23 Feb 2014, 11:31 am »
Sent Mike an email
Thanks James
