NAD CD player synergy with Adcom amps
0 Members and 1 Guest are viewing this topic. Read 2477 times.
gnuyork
« on: 23 Feb 2014, 12:56 am »
Does anybody know if NAD cd players would sound good through Adcom gear? I have the GFA 5500. Looking for a reasonable CD player to match.
Thanks.
gnuyork
Re: NAD CD player synergy with Adcom amps
« Reply #1 on: 24 Feb 2014, 12:55 pm »
Anybody have an opinion on this? ^
I.Greyhound Fan
« Reply #2 on: 24 Feb 2014, 03:35 pm »
I can't help you with the NAD but if your system is bright consider a Marantz CD player,  with out knowing your budget here are some lower cost recommendations- take a look at the Marantz CD5004 and 6004/6005.
http://www.musicdirect.com/search.aspx?searchterm=cd%20players
 If your system is warmer or neutral consider a Music Hall or Cambridge Audio.  I own an Adcom AVR for HT, a Music Hall CD25.2 cd player, now used as a transport and I have owned a Cambridge Audio 840c and 740c and a Marantz SA8001 in the past.
Have you considered an outboard DAC?
decal
« Reply #3 on: 24 Feb 2014, 04:17 pm »
I used an NAD C516BEE player with my Adcom GFA535 amp and it was real nice sounding.
thunderbrick
  • I'm just not right!
« Reply #4 on: 24 Feb 2014, 04:25 pm »
Preamp? Speakers?  Tastes?  Music genre?   :scratch:  All of those figure in to recommendations.
gnuyork
« Reply #5 on: 25 Feb 2014, 12:02 am »
Ah sorry... the preamp is the Adcom GTP 500 II (not crazy about it, but the seller threw it in for free with the amp). Speakers are made by a company called SLS - they are towers with ribbon drivers , and sound quite nice. I do have a 12 inch sub as well, but not currently hooked up. Speakers retail in the 5K ish range and $2500 for the sub.
Tastes are mostly Jazz, blues, and rock - though I would like to get into some classical at some point. Right now I am using a SONY DVD player - system sounds pretty good, but I have a feeling I can do better with a proper CD player. I plan to add a turn table at some time in the future. Missed out of a Rock III here from a seller (got damaged when being packed for shipping). In the short term I'd like to get a proper CD player. It would not hurt my feelings if the sound is on the warmer side.
gnuyork
« Reply #6 on: 25 Feb 2014, 12:08 am »
Yes, but I am inquiring because there is an NAD 545 for sale in the classifieds. There is also the Cambridge Azure 640C.  I'm not looking to spend a lot right now, but both of these are within budget for used components.
Also I used to have a Squeezebox running aiffs in iTunes, and though it was convenient, I found cd playback on my DVD player to sound better with the same material.
I.Greyhound Fan
« Reply #7 on: 25 Feb 2014, 12:39 am »
It looks like you prefer a warmer sound.  I would definetly go with a Marantz.  Even the lower end Marantz Cd players have the warmer house Marantz sound.  There are good deals on the 5004, 6004 and 6005 at the Music Direct link I posted earlier.
This place has good prices as well on Marantz gear if you don't mind factory refurb's-
http://www.accessories4less.com/make-a-store/category/CDPlayer/Home-Audio/CD-SACD-Players/1.html
gnuyork
« Reply #8 on: 26 Feb 2014, 12:31 am »
Well not too warm, I guess I am looking for a more analogue sound if that even makes sense (less digital harshness).
