0 Members and 1 Guest are viewing this topic. Read 10092 times.
What's the primary benefit, other than not needing good soundcard installed in your PC or laptop? Is jitter nearly eliminated since it's interfaces directly with the spdif on the dac?
the computer must be equipped with USB 2.0, or will USB 1.0 will work also?
Steve, do you think this would be practical with my Scott Nixon Tube Dac? It only has 1 input (coaxial).
What is the difference between using the motherboard SPDIF output to the DAC rather than the USB out to the DAC, assuming the use of something like Foobar? Is there a greater reduction in jitter with USB compared to a MB SPDIF? Or are these alternative ways of accomplishing essentially the same thing? I know using a MB SPDIF out was much better than my transport.
Steve,Does it make a difference if you connect the USB port with a cable or via a wireless usb network adapter?
Steve,What is the longest the USB cable can be?George
I think usb connection is a very good connection for audio. But, the media source is important too. From my deduction, storing music inside an external notebook drive and transfering the data via usb to an external dac seems to be the way to go for hifi pc audio. ...
