need a cheap amp to match stratos for surrounds
0 Members and 1 Guest are viewing this topic. Read 1798 times.
fishcall
« on: 13 Aug 2004, 03:43 pm »
i am looking for a cheaper amp to power my surrounds, can anyone suggest one that would closely match the stratos line. my system will consists of an odyssey stratos ht3 for LCR channels and b&k ref. 21 processor powering paradigm studio ref. ht. i am looking for a cheaper amp to power my rear speakers (paradigm studio ref. 20v.2). any suggestions?
Marbles
« Reply #1 on: 13 Aug 2004, 03:52 pm »
The Khartago is probably more than you want to spend, but at $750 would be a natural suggestion.  I would use it for the side surrounds and move the BK to rear surround duties.
jackman
« Reply #2 on: 13 Aug 2004, 04:12 pm »
What about the two amps for sale in the classified section (Scott Nixon design)?  They look cool and are only $300 for the pair.  Might be a good choice on a budget.
J
JackD
« Reply #3 on: 13 Aug 2004, 04:36 pm »
Fishcall
Try this. I bought one as a fill-in when my normal amp went back to the factory for replacement of a bad transformer. Has stayed in the system since.  Also allows for the flexibility of two or four channels.
http://www.soundcity.com/page.php?pg=product&id1=547&id3=11&mcat=HOMEAUDIO&product_id=1137
