Ncore 400 no longer working...
0 Members and 1 Guest are viewing this topic. Read 3319 times.
Jeff V.
« on: 15 Feb 2014, 12:49 am »
I was doing some work on a DIY preamp & while trying to isolate some noise I moved my input to the amp, heard some more noise then no sound.  I use balanced inputs, which I did wiggle at the connection.  Not sure if I shorted something?  The lights come so the fuse should be good.  I know I will have to swap pieces with its mate to isolate which board is at fault.  Just wondering if anyone may have any insight to this problem.  Thank you!
Jeff
Jeff V.
Re: Ncore 400 no longer working...
« Reply #1 on: 15 Feb 2014, 03:10 pm »
I have had no luck finding the problem. The amp board lights up. I guess that this just shows it is receiving power & not that the amp is working properly. For anyone who has gotten into the guts of these boards, is there any thing I should test with a meter?
Thinking I may have fried a circuit somehow I have emailed Hypex to see if they can do anything for me.
-Jeff
jtwrace
    • TIPP YouTube Channel
« Reply #2 on: 15 Feb 2014, 04:40 pm »
Is it both amps?  Have you swapped channels?  Have you swapped NC400 boards?
What trouble shooting have you done?
Jeff V.
« Reply #3 on: 15 Feb 2014, 05:52 pm »
The trouble is with one amp.  It is a monoblock configuration.  I will swap boards today to see if the trouble is the amp or PSU.
All I've done so far is swap cables & checked the connections.
Jeff V.
« Reply #4 on: 15 Feb 2014, 07:33 pm »
Swapped the boards & it's the NC400 that's blown.  Not a good weekend.
jtwrace
« Reply #5 on: 15 Feb 2014, 07:33 pm »
Send Hypex an email and they will get it taken care of.  No worries.
Jeff V.
« Reply #6 on: 15 Feb 2014, 07:50 pm »
Thanks for the encouragement.  I'll post how things turn out.
Jeff
Jeff V.
« Reply #7 on: 26 Mar 2014, 11:30 pm »
Hypex sent me a new amp.  Back in business.  Great customer service!
maplegrovemusic
  • Please Be kind to your ears .... Treat your room
« Reply #8 on: 26 May 2014, 11:59 pm »
did you have to pay for the replacement ? if so how much ?
