0 Members and 1 Guest are viewing this topic. Read 25844 times.
Are you referencing the TPA3116 2.1? According to ebay, power output is stated as '50W+50W+100W Class D'.
If your are going to go for a T-amp then go with one with more power like this Topping TP-60http://www.tpdz.net/en/products/tp60.htmor the Dayton DTA 120Although that Onkyo 9555 that I posted is a great buy and you won't have any worries about power.Here is a nice review on it-http://www.stereophile.com/integratedamps/907onk
FYI, The TPA amps are not Tripath chips. They also sound much better than any of the Tripath. The TPA3110 is 10w, but the 3116 listed earlier is capable of 50w stereo and 100w mono.
These amps are very intriguing, but it seems everyone is using them with fairly efficient speakers. The Pioneers are 85db @ 1 watt. Also, the physical size of caps seems rather quite small considering the claimed power output. What am I missing?
You're hearing from multiple folks that have used these amps with the exact speakers you're trying to pair with.
Here are the Pioneer BS22-LR's powered by a TPA 3116. I also have driven the Pioneers with a Topping, Dayton DTA100 and TK2050/Meanwell. It's no contest as the TPA 3116 sounds better and delivers more power than the others. Pair the TPA 3116 with a $50 6n3 preamp and it goes to another level.
Looking at the TPA thread, I got the impression most people were using various speakers by Klipsch, Lowther and Various types of horns... In any case, my budget will allow me to spend considerably more, especially if it is merited. So in other words, although the TPA at its price point is untouchable, is there something else that would make for a functionally better match with the Pioneer BS22 speakers for a few hundred dollars more?
Why do you want to spend hundreds for an amp to drive the pioneers? They are nice little speakers but thats about it. I have heard them hooked up to a $7000 system and I was not impressed. They sounded good for the money but not great.Hey Poultry, Its BR from the AR forum. Whats up?
Hi BR,Good to see you over here. Are you still on AR? I got tired of talking to myself over there
I'm thinking a bigger amp with a beefy power supply might drive them better.
